LED Help - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-26-2012, 07:15 PM   #1 (permalink)
Default LED Help
I need some help! We own a 2009 Aero 750. The brake lights have the 3 flash warning when you apply the brakes. I put the Radiantz LED brake light and the Led Rear turn signal lights on the rear. They work great! The turn signal and brake light really light up when you apply the brakes and also the rear turn signals with the LEDs work perfectly. I decided to add amber LEDs to the front turn signals to have LEDS all the way around. When I added the front LEDS (also Radiantz) they flash very fast which in turn causes the rear turn signals to also flash very fast. When I put the stock bulbs back in everything works fine. I have read most of the threads pertaining to LEDs and I am somewhat confused!! Some say add digital flashers and some say add new flasher relay and others say add a load equalizer. My second question is, where is this located on the bike? Is it in the Side Cover or Headlight housing, this is where the noise is coming from when it flashes. When the turn signals are on, a green light will light up on the triple tree indicating that the signal is on. Any help would certainly be appreciated.
bj1406 is offline   Reply With Quote
Old 04-26-2012, 07:23 PM   #2 (permalink)
Big B's Avatar
In my wife's o5, it's in the headlight bucket. Not sure if it's still in there on yours. You don't have a service manual, if not, invest in one. Get an electronic t/s flasher and it will solve your problem. There's not enough load on the LED bulbs hence the fast flash rate.
Bernie
08 M109R *SLAMMED*
02 Sabre, gone but not forgotten
Big B is offline   Reply With Quote
Old 04-26-2012, 07:30 PM   #3 (permalink)
superdiver's Avatar
Location: Ketchikan, Alaska, salmon capital of the world!
What is an "electric t/s flasher"? and what does it do?
superdiver is offline   Reply With Quote
Old 04-26-2012, 08:47 PM   #4 (permalink)
Scrapdog2grand's Avatar
Its the turn signal flasher/relay, only its electronic, and does not work with the bi-metalic element.
Show Chrome Accessories (Big Bike Parts) LED Flasher Relay
this one should be plug and play.
1999 VLX
1998 SA750
2003 SA750
Old 04-26-2012, 09:04 PM   #5 (permalink)
SnoGhost13's Avatar
Listen for the clicking when the signal is on if you need to locate it. Once you find the right area, you should be able to feel the click to be sure you change the correct unit.
Sent from my Samsung Epic 4G Touch using Motorcycle.com App
Joe
08 VT750C2 Shadow Spirit
SnoGhost13 is offline   Reply With Quote
