I called my local bike shop today to see about an oil change. They said it would cost $55. So now my question is, how do I change my own oil? I have no idea what to do. Any advise is appreciated.
Sent from my Motorcycle iPhone app |
Take it to the shop.
Or get a shop manual. Sent from my DROID BIONIC using Motorcycle.com Free App
![]() 2006 Shadow Aero 750 Switchblade windshield, Cobra Floorboards, Saddlemen Hardback Quick-Release Bags, Light Bar, Wind Diverters, Highway Bars, ISO Grips, Chrome Radiator Cover, Raised Handlebars, Vance & Hines Straight Shots, Freeway Blasters |
#3 (permalink) |
Read this link... Newbie Question about oil change
Also, watch the You Tube video for tips. I did my own oil change and had never done it before either. It wasn't too bad. Based on my "mechanically challenged" ability, I will offer this advice, from a first time experience:
Edit: My recommendations... Oil = Shell Rotella T6 Filter = Purolator L14612
2007 Honda Shadow Aero 750
#4 (permalink) |
It is actually easy, at least after the first time you change it.
However, that being said -- you just might want to take it to the shop (the first time) and make sure they let you watch. Then you're good to go for the rest of your motorcycle life. Also, some shops actually charge more than $55 to change oil, believe it or not. And by the time you're finished getting an oil drain pan, funnel, oil (especially synthetic) you're gonna be up to around $55 anyway -- the first time. And while it's in the shop (if that's the way you decide to go) have them point out some general maintenance tips for your bike. They should be happy to do so. (Famous last words.)
![]() HONDA OWNER'S MANUAL 2003 Shadow Spirit VT1100C (1) FILL TANK WITH GASOLINE (2) RIDE UNTIL EMPTY (3) REPEAT STEPS 1&2 Last edited by GiveItToMikey; 05-01-2012 at 03:57 PM. |
#5 (permalink) |
ButchA pretty much covered what you need to do. The only thing I would add is it really helps if you can get the bike a little higher off the ground to allow for easier access underneath the bike. What I usually do is drive the bike up onto a couple of pieces of 2X8 boards, one under the front tire and one under the back, and then a third piece placed under the kickstand. This raises the bike a couple of inches which makes all the difference in terms of getting to the drain plug, putting a drain pan underneath, and accessing the oil filter.
All in all it's a simple procedure and you can do it for much less than what a shop would charge. If that is the only maintenance you ever do over time, you'll save a considerable amount of money.
![]() 2008 750 Aero |
#7 (permalink) |
55 is kind of a lot in my opinion. Yeah you'll need to buy a drain pan and funnel and oil and filter, but that wouldn't be that much (maybe about 5 bucks for a motorcycle drain pan, funnel is about 2 bucks, oil maybe 10 or so, and filter about 15 if you look around). Although in saying that I also know that prices for things vary state by state. I have to agree though, either watch a few videos of it on youtube and have your service manual ready, or take it to the shop and watch how they do it.
#8 (permalink) |
Butch covered it very well. I do recommend using a box end wrench to avoid rounding the drain plug with an open end or cresent wrench. Good advise always to use box end or sockets whenever you can. Select an oil for your climate but something like the rotella synthetic will cover about anything you might want to ride in. I prefer Mobil 1 10w40 and have used a filter from Walmart, the Purolator Classic. I hope it is as good as the Supertech was. The 2x8s sound like a really good idea, it is a bit close especially to use the wrench. Good luck and I have replaced my washer with some copper ones from the autoparts store.
