Rear wheel won't come off.... - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-07-2012, 06:55 PM   #1 (permalink)
Czech's Avatar
Send a message via Skype™ to Czech
Default Rear wheel won't come off....
... so got 83 vt750 and I was going to remove the rear gas tank, but first you have to take the rear wheel out. I can not for the life of me loosen the 22mm nut at the end. I have a socket with driver on it and it just slowly turns but it does not look like it is coming off. I do not want to demage the spindle or the nut so I stopped. Is this supposed be so hard to get it off or is there a trick to it? The manual is clear, but I thought I ask the gurus anyway. Thanx
1983 VT750C
Czech is offline   Reply With Quote
Old 05-07-2012, 07:21 PM   #2 (permalink)
Motrcyclr's Avatar
Do you have a wrench on the other end of the bolt? it is a through bolt.
riding since 1969, currently a 2009 Shadow Spirit !
Motrcyclr is offline   Reply With Quote
Old 05-07-2012, 07:50 PM   #3 (permalink)
Czech's Avatar
there is no head on the other end. Just hole thru the spindle, but that hole does not move at all so I am wondering if I am just about to break the spindle.
1983 VT750C
Old 05-07-2012, 07:57 PM   #4 (permalink)
Motrcyclr's Avatar
I'll quit guessing on stuff I don't have first-hand knowledge of.
I doubt you could break the spindle with the leverage on a standard wrench, unless ya jumpin on a 4' cheater bar attached to a 18" breaker bar?
Old 05-07-2012, 08:20 PM   #5 (permalink)
Keep turning the nut, you won`t break the "spindle"/axle/bolt...
IF it turns you can put a phillips screwdriver (+) through it to hold it...
Good Luck,
"D"
`98 VT750 A.C.E.
www.mrf.org
www.MSF-USA.org
http://www.ama-cycle.org/
Old 05-07-2012, 08:34 PM   #6 (permalink)
Czech's Avatar
No, no cheater bar here, just 18" breaker bar.
1983 VT750C
Old 05-07-2012, 08:37 PM   #7 (permalink)
Czech's Avatar
Good Luck,
"D"
I'll take your word for it. It does not turn so something is giving up. Thank you guys for your help. As soos as stops rainning I will give it another shot.
1983 VT750C
Old 05-07-2012, 09:37 PM   #8 (permalink)
Czech's Avatar
You were right. Somebody before me screw-up the threads so it was hard to turn, but I got it out. Will fix the axle tmrw in the shop.
1983 VT750C
Old 05-08-2012, 04:07 AM   #9 (permalink)
83 HONDA VT750C SHADOW REAR AXLE | eBay
You can get them cheap on ebay.
eots is offline   Reply With Quote
Old 05-08-2012, 07:57 AM   #10 (permalink)
gmck's Avatar
I would not try to fix it. it is way too important, get a new one. its like your life depends on it.
