How to clean reserve tank... - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-08-2012, 10:56 PM   #1 (permalink)
Czech's Avatar
Send a message via Skype™ to Czech
Default How to clean reserve tank...
..the bike was sitting for 10 years with main tank empty, but the reserve tank had about a liter of old gas in it that I managed to get out. No sludge or rust just nasty old gas. I would like to clean it to make sure I do not plug the fuel filter, but not so sure how to go about it. Garden hose ? Vinegar ? Any ideas ?
1983 VT750C
Czech is offline   Reply With Quote
Old 05-08-2012, 11:10 PM   #2 (permalink)
Fellenz's Avatar
i would let it soak in kerosine for a while, then swish it out with some new gas.
Just a thought....I'm sure someone has a much better answer than me
Fellenz is offline   Reply With Quote
Old 05-09-2012, 01:39 AM   #3 (permalink)
superdiver's Avatar
Location: Ketchikan, Alaska, salmon capital of the world!
I have the 84 700, and the reserve is a pain to get out. If it were easy I would take it out and clean it...lol
superdiver is offline   Reply With Quote
Old 05-09-2012, 08:22 AM   #4 (permalink)
Czech's Avatar
I know. I did take it out ,since I want to do it right.
1983 VT750C
Old 05-09-2012, 11:08 AM   #5 (permalink)
Remove the petcock, that'll make it easier to empty the reserve.
shadowrider482002 is offline   Reply With Quote
Old 05-09-2012, 11:12 AM   #6 (permalink)
Czech's Avatar
OK guys, lets' make this clear. The tank is out no lines on it, no petcock. I just want to know what product to use to clean the inside. Thank you.
1983 VT750C
Old 05-09-2012, 12:39 PM   #7 (permalink)
No rust; no sludge: just use a litre vinegar (mild acid) seal the tank and shake and let sit for a day on the reserve side or if there is a lot of gum use muratic acid.
G.
gdb069 is offline   Reply With Quote
Old 05-09-2012, 12:41 PM   #8 (permalink)
Czech's Avatar
Originally Posted by gdb069 View Post
No rust; no sludge: just use a litre vinegar (light acid) seal the tank and shake and let sit for a day on the reserve side or if there is a lot of gum use muratic acid.
G.
...now that was helpful - thank you.
1983 VT750C
Old 05-09-2012, 12:57 PM   #9 (permalink)
superdiver's Avatar
How hard was it to remove the tank?
Old 05-09-2012, 12:59 PM   #10 (permalink)
Czech's Avatar
Well, you have to take the rear wheel off, remove part of a fender and then she just drops down. Was not too bad.
1983 VT750C
