stator replacement - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-09-2012, 02:33 PM   #1 (permalink)
Default stator replacement
Guys, Need a little help. On a '95 1100 spirit is the stator attached to the cover or bolted to the case? I'm looking at buying another one (bike) that the current owner has already replaced the regulator on. What is the correct way to test the stator. According to him it charges fine at idle but won't charge when accelerated. How bad of a job to replace? Ideas? TIA
"Ride 'em Don't Hide 'em"
unclet is offline   Reply With Quote
Old 05-09-2012, 03:26 PM   #2 (permalink)
rieckena's Avatar
It's attached to the engine side cover. The job isn't too hard, I did mine last year. Replace the gaskets when you do it. Here's mine:
You'll note it's in there backwards, I switched that around after I took the pic.
1995 ACE VT1100C2
1975 CB550Four
1994 Toyota 4x4 22RE 5speed
rieckena is offline   Reply With Quote
Old 05-09-2012, 07:54 PM   #3 (permalink)
Search this tech forum for charging voltage issues, you'll find links to electrosport troubleshooting guides,then lots of people will offer up help with any questions you run in to. I changed mine on my 2000 sabre recently,sometimes you'll notice higher volts at idle than as you rev up higher,it's a fairly normal situation.If you do end up replacing it yourself,take your time and observe details like how the rubber grommets that hold the wires in place on the cover are installed,make sure if the dowel pins come off attached to the cover you pull them and put them on the case to aid in gasket installation,just a couple things I learned the hard way
ncsabrekingz is offline   Reply With Quote
Old 05-10-2012, 09:52 AM   #4 (permalink)
Earthling789's Avatar
It is a fairly easy job, but cleaning the old gasket off is honestly the hardest, most time-consuming part of the job. I recently did mine, and it took about 5-hrs from gathering tools to ready-to-ride.
I'll impart some lessons learned... hopefully they will help you:
Lessons learned...
  1. That cover is really on there... took a lot of patience to NOT use the bigger hammer or start prying.
  2. Starter gears... watch-out.. they jump off their shaft when you're not looking And make sure they are back (correctly) before you re-assemble.
  3. Using a 2x4 across the top of the crank casing (above the stator), and a small gear puller, catching two points of the stator, lifted it out beautifully... Took less than 30-sec to break it free / pull it out.
  4. Gasket cleaning sucks!! I think the factory actually melts the gasket into place during assembly... (don't use anything sharp like a knife to "dig" the gasket loose, you'll gouge the housing... patience, a plastic putty knife, and some gasket solvent will go a long way)
  5. A dab of gasket seal here and there helps hold that new one in place when trying to re-assemble.
  6. It works better if the two guide tubes are on the same side as the gasket when assembling... so if you have one on the cover, and one on the engine side... carefully move one of them. It makes life easier!
  7. Number your bolts as you remove them! After removing the clutch slave cylinder, I pulled bolts from the crank cover, starting at the top-center, moving clockwise. I numbered the bolt's shaft with a sharpie, and made a tick-mark on the bolt hole at clock-time to correspond to the # on the bolt... an old trick I learned from my father which is most helpful when changing crank bearings so you get the same bolts in the same holes.
  8. Change your oil VERY soon after replacing the stator... just in case you get any gasket debris inside the engine... plus your bike will thoroughly enjoy FRESH OIL
Current -
2002 VT1100C2 Sabre
1985 VT700C Shadow
1999 CB750 NightHawk (son's ride)
"The Hardest Part About a Zombie Apocalypse, Will Be Pretending I'm Not Excited"
Earthling789 is online now   Reply With Quote
Old 05-10-2012, 08:48 PM   #5 (permalink)
Thanks guys!
