Losing power 06 1100 Spirit. Thanks. - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-16-2012, 04:55 PM   #1 (permalink)
Default Losing power 06 1100 Spirit. Thanks.
Hey guys,
I just bought an 06 1100 Spirit that has been well care for as far as I can tell. The bike runs well, with one exception. The motor stumbles and loses power when I roll on more than about ¾ throttle. It’s most noticeable in 3rd, 4th or 5th gear. As soon as I roll off the throttle a little, it runs smooth and the power comes back.
The air filter was dirty and I just put in a K&N but there is no difference. If it comes down to carb adjustment, does the tank need to come off for this? I will appreciate any input…thanks.
Regards,
Mark
Mark_ is offline   Reply With Quote
Old 05-16-2012, 05:20 PM   #2 (permalink)
JBourquin's Avatar
Try a fuel filter before you go digging into the carbs..
Plus, run a tank or two of either Seafoam or Startron first. May not help, but definitely not gonna hurt to try first.
2001 VT1100C
-Cobra Slash Cut
2008 FLSTC
-V&H Big Shot Staggered
-SE Heavy Breather
-Power Commander III USB
-Batwing Fairing from Reckless w/ Infinity 6x9's
-70T Rear Secondary
2002 VT750 Spirit - SOLD
JBourquin is offline   Reply With Quote
Old 05-16-2012, 05:37 PM   #3 (permalink)
Thank you, tried the Seafoam...no luck. Tank has to removed to access fuel filter?
Mark
Old 05-16-2012, 07:30 PM   #4 (permalink)
Spool's Avatar
Mark
The fuel filter is underneath the battery box in front of where the swingarm connects. You have to get under the bike and look up to see it. It's a pain in the rear to reach up in there and get it out but is doable with some patience.
2002 Shadow Spirit 1100
Spool is online now   Reply With Quote
Old 05-16-2012, 08:00 PM   #5 (permalink)
oblivion_twister's Avatar
but to answer your question about carbs, yes, remove seat, remove tank and then the real fun of several connections in a very small space starts.
oblivion_twister is offline   Reply With Quote
Old 05-16-2012, 08:13 PM   #6 (permalink)
How many miles and has the bike been sitting for a period of time?
2006 Honda Sabre
Old 05-17-2012, 05:05 PM   #7 (permalink)
The bike has 20,000 miles but I'm not sure if it sat much before I bought it. Talking to the previous owner, it has run this way the whole time he owned it (3 years) but it didn't bother him. Of course he didn't mention anything while I was looking to buy it.
Mark.
Old 05-17-2012, 06:17 PM   #8 (permalink)
John Hopkins's Avatar
change the filters, oil air and fuel, change the plugs, the oil and coolant and the hydrolic fluid, check or change the shoes and pads, make sure the caliper pistons are free, remove, check the level and fully charge the battery and replace the tyres if they are suspect, also change the driveshaft oil..then take it for a 200 mile run to blow the cobwebs out of it, If after all that you still have trouble you may have to overhaul the carbs..somewhere on here is a repair instruction..
John.
John Hopkins is online now   Reply With Quote
Old 05-17-2012, 08:07 PM   #9 (permalink)
my 2000 Sabre was beginning to hesitate like that when I was at around 60mph and would get into the throttle fairly hard. I put a new fuel filter in and it's quite smooth now. It took me about an hour and a half with moderate cussing to do,but it is something you can do yourself.
ncsabrekingz is offline   Reply With Quote
