Stupid Question: Left Grip Slipping - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-23-2012, 09:44 AM   #1 (permalink)
rsmm0224's Avatar
Default Stupid Question: Left Grip Slipping
The left hand grip on my 83 Shadow keeps slipping down while riding. It will get down like an inch and I push it back up and after awhile it slips back down. What's the best way to keep this from happening? Do I need to replace the grip or can I just put some super glue in it? Is there some special rubber to steel epoxy and do I need to scuff the steel first?
I know this should be an easy thing to figure out but thought I would bounce it off you guys first. You seem to have "been there, done that" with just about every issue possible on these bikes.
rsmm0224 is offline   Reply With Quote
Old 05-23-2012, 09:49 AM   #2 (permalink)
jimnfor's Avatar
You can use spray adhesive, aerosol hair spray etc. Spray it inside the grip, not a ton, just a good coating. Then push the grip back on, no need to prep the bar. Let it sit for a while before you try 'checking' it.
BUT, if the grip is slipping off that easy it may have stretched enough to where it won't fit snug. If that is the case, time for new grips.
2001 VLX 600
jimnfor is offline   Reply With Quote
Old 05-23-2012, 09:54 AM   #3 (permalink)
rsmm0224's Avatar
Thanks, I'll try that.
Old 05-23-2012, 01:30 PM   #4 (permalink)
Earthling789's Avatar
They make special grip-adhesives, but for the factory, foam-grips, jimnfor is right... any spray adhesive will do well... and so will common rubber-cement. Superglue will be a pain to clean up if you ever decide to upgrade grips. The spray adhesives and rubber-based adhesives are much easier to deal with after-the-fact.
Current -
2002 VT1100C2 Sabre
1985 VT700C Shadow
1999 CB750 NightHawk (son's ride)
"The Hardest Part About a Zombie Apocalypse, Will Be Pretending I'm Not Excited"
Earthling789 is online now   Reply With Quote
Old 05-23-2012, 02:16 PM   #5 (permalink)
superdiver's Avatar
Location: Ketchikan, Alaska, salmon capital of the world!
I put on cheap grips from Ebay, and they fit like CRAP! I glued them on and they never stuck. I ordered the "real" ones from the Honda dealership and took the old ones off and they fit AMAZING!
ie dont get the cheap crap!
superdiver is offline   Reply With Quote
Old 05-23-2012, 05:14 PM   #6 (permalink)
Hair spray works perfectly.
Old 05-23-2012, 05:31 PM   #7 (permalink)
rsmm0224's Avatar
Actually turns out I have none of that in the house! haha I'll have to get some hairspray from my gf.
Old 05-23-2012, 06:02 PM   #8 (permalink)
You have probably gotten some water under the handgrip...
Next time it starts moving bring it all the way off and dry the handlebar and the inside of the grip, then reinstall it...
It`ll prolly stay put once you do that,
Don`t cost nothing to try it,
"D"
`98 VT750 A.C.E.
www.mrf.org
www.MSF-USA.org
http://www.ama-cycle.org/
Old 05-24-2012, 08:40 AM   #9 (permalink)
adlowe's Avatar
I had that problem for a year or so after I changed the handlebar. I tried half a dozen different suggestions and a few ideas of my own. Most worked okay until the weather got hot and (sometimes or) I parked the bike in the sun. I tried two different grip glues with no success. (Yes, I cleaned out the inside of the grip very carefully before each application.)
The problem finally disappeared when I got grip glue from a Harley shop. Guess they only stock the good stuff when it comes to repairs.
Art's 1999 Shadow 1100 ACE
adlowe is online now   Reply With Quote
Old 05-24-2012, 11:06 AM   #10 (permalink)
When I changed the bars on mine I used grip tape on them. Not the stuff for sports handles but the really rough stuff for steps. One strip lengthwise and hammered the grip on. Fits very tight.
Nick
84 VT700c Mostly stock. For now
Cautrell05 is offline   Reply With Quote
