83 vt500c shifter question - Honda Shadow Forums : Shadow Motorcycle Forum
Old 06-17-2012, 12:46 PM   #1 (permalink)
Default 83 vt500c shifter question
I'm very new to riding and have only rode about 100 miles so far. I'm having a little problem with shifting because I can barely get my boot under the shifter since it's so stubby. It's to short to reach the middle of my boot, it just catches the edge of my big toe which is a little frustrating. Is there any way the make it longer?
83vt is offline   Reply With Quote
Old 06-17-2012, 12:53 PM   #2 (permalink)
There is no adjustment to make it longer, you can adjust it up and down, but the only way to make it longer would be to cut it and weld a piece of flat bar or something in there
83 VT 750 C Shadow
orlenz is offline   Reply With Quote
Old 06-17-2012, 01:00 PM   #3 (permalink)
I was hoping maybe there was a replacement after market shifter someone might know of. Are all bikes the same, except the ones with forward controls?
Old 06-17-2012, 01:06 PM   #4 (permalink)
No they are not all the same. If you adjust the shifter up you should be able to get your boot under it comfortably.
dgraves49 is online now   Reply With Quote
Old 06-17-2012, 01:09 PM   #5 (permalink)
I will try adjusting it up. It may also be my boots. They are really nice, but the bottom tread sticks out the sides about a 1/4 inch.
