2004 Sabre risers - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 06-28-2012, 11:51 AM Thread Starter
pctec860's Avatar
2004 Sabre risers
Does anyone know what the biggest risers I can get for my Sabre? What I have on it now are kuryakyn 3 inch. I am looking for something with a pullback. But I don't want to change cables, just the risers.
Thanks in advance
pctec860 is offline
post #2 of 8 (permalink) Old 06-28-2012, 02:38 PM
What are you doing about the bars? With stock cables and bars you could probably get a way with a total increase of maybe 4" rise/pullback
93gc40 is offline
post #3 of 8 (permalink) Old 06-28-2012, 02:54 PM Thread Starter
pctec860's Avatar
4" isn't that much, I have 3" on it right now and want something a little higher. I was thinking possibly another 3 inches would work, maybe not. I think I might just have to dig into it and undo the bars from the risers then measure how much free play I will have.
pctec860 is offline
post #4 of 8 (permalink) Old 06-29-2012, 01:27 PM
3-4" of additional rise/pullback, NOT a 4" riser, were talking a 6"-7" riser here, maybe. Or say and 6" rise with 1" of pull or some other combo.
93gc40 is offline
post #5 of 8 (permalink) Old 06-29-2012, 02:03 PM
You won't be able to go too much more without new cables. You can get a couple more by routing cables and wiring behind the triple tree.
jpr1968 is offline
post #6 of 8 (permalink) Old 06-29-2012, 05:42 PM Thread Starter
pctec860's Avatar
93gc40, So you think I should be able to get away with 4 rise 2-3 pullback? That is what I am actually looking for. I don't want too much. I feel like I am leaning forward to much. This would make it perfect for me.
2004 Sabre VT1100C2
Mustang seat, Cobra Dragster exhaust, Rejet to CarbJetKits.com 185,190, and 45.
Hard work spotlights the character of people; some turn up their sleeves, some turn up their noses, and some just don't turn up at all.
Sam Ewing
pctec860 is offline
post #7 of 8 (permalink) Old 06-29-2012, 07:08 PM
I have a Sabre that I put Aeromach risers on with stock bars. 4" rise and 1 1/2" pullback. With stock cables it would pull the throttle open when the bars went full left and would pull the choke iff full choke is I moved the bars to the right. You may be able to use stock cables if you route everthing behind the triple tree.
jpr1968 is offline
post #8 of 8 (permalink) Old 06-30-2012, 02:57 AM
supv26's Avatar
I had the same issue when I added Cobra risers. I had everything installed and was loving the feel of the bars bring higher and closer then turned them. The motor reved up and it pulled the choke on. Bummer!!! I didn't want to invest in longer cables so I just put the stock risers back on.
It's not the destination, it's the journey!
2003 1100 Honda Sabre
It's not the destination, it's the journey.
supv26 is offline
