Bike Details: 2006 VT600CD
I am in need of adding on some rear turn signals. I had my eyes set on these,Razor-Eyes. The stock ones had been removed by the previous owner who replaced the rear fender with a custom fender and only added brake/run lights. First, will I need to buy aLoad-Equalizer to allow those lights I linked above to work? Will I need one Load-Equalizer per light or just one for the two? Is there some where I can order or find OEM wiring ends to clip right into the factory ends? Any help is greatly appreciated. I can also take pictures if needed to aid in any suggestions.
![]() MILWAUKEE,WI 2006 VT600CD ● Custom Straight Exhaust ● Custom Ram Air Intake ● Joe Florida 207 Multi-Color Accent LED's Light's in Action ● Jesse James (West Coast Choppers) 9" Rear Fender ● KÜRYAKYN ISO Grips & KAISER™ PEGS ● 6" Forward Controls ● Willie & Max Compact Slant Saddle Bags & Tool Pouch |
I would just replace your stock flasher relay with an electronic version. If all you are doing is making the rear turn signals LEDs that is all you will need to do to make them flash properly.
![]() ![]() ![]() ![]() 2011 Phantom |
#3 (permalink) | |
Don't bother with a load equalizer. I've got LEDs and I use the Custom Dynamics Standard flasher. Amazon.com: Custom Dynamics Standard DOT Flasher EDFR
![]() Check this thread for where the book is now - it's traveling! Make sure you get your shot at it!! And check the Google Map here! The Trip map is here My VTX Garage! |
#4 (permalink) |
Thank you MadChemist and Canyon. Doing this on my own will be saving me about a $100.00+ that the dealership wanted to rake me over for an install.
#5 (permalink) | |
![]() (ignore my wiring in this pic ... it was a temporary work in progress)
![]() Keep the rubber side down ... unless of course you have a rubber head! My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf |
#7 (permalink) | |
Tridon/Hazard Warning Flasher (EP35) | AutoZone.com
