HELP Video on 2007 Aero 750 oil change - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 4 (permalink) Old 07-25-2012, 06:14 AM Thread Starter
Are there any video's out there showing the oil and filter change on a 2007 Honda Shadow Aero 750 Shaft drive? I heard that a pin is difficult to remove and replace and would like to see it done.
journey is offline
post #2 of 4 (permalink) Old 07-25-2012, 06:22 AM
I watched an oil change for a 2009 Honda Shadow Aero on YouTube a few months back. If you type "2009 Honda Shadow Oil Change" in YouTube's search, it should come up. I'm not sure if everything would be the same, but it might help.
When I've taken the chrome side cover off my engine (2009 Honda Shadow Spirit 750) there is a pin/clip that holds the cover on along with an Allen bolt. It's tricky the first time because it's hard to see, but I eventually got it. There is a washer that goes with that clip too. I'm not sure if this is the "pin" you are referring to. By removing this particular cover, it does make seeing the oil filter easier but at least on my bike, it's not necessary to take that cover off.
DRVMN is offline
post #3 of 4 (permalink) Old 07-25-2012, 07:09 AM
tigrzeye is offline
post #4 of 4 (permalink) Old 07-25-2012, 09:48 PM
I never took off the side cover to change the oil filter. I reach under with a oil filter wrench and remove filter. Install new filter hand tight an a 1/4 turn. Thats it in a nut shell. Go for it!!!!!!!!!!
RICK8961 is offline
