I bought a Big Bike Parts Contour Driving Light kit off of one of my friends. I was going to hold out for some of the Kuryakyn lights, but he offered the light bar for $75, so I jumped on it.
The one thing I was concerned about was that it was mounted on a VTX 1300, but I figure if worse come to worse I can fab up a different mounting plate since it is removable from the bar itself. My main concern is that there is only one blue wire coming out of each light. Shouldn't there be a ground wire as well? Can I just wire the light straight into the headlight wiring? |
on most aftermarket lights, the lights are grounded to the bracket itself. So if the light bar gets grounded to the bike, then that will be your grounding for the lights. Then wire the lights to your power source.
2007 Shadow Spirit 1100
#5 (permalink) |
Check out the threads for wiring light bars. The ideal way to do this it to switch them via a relay. I bought a aux lighting relay kit from oreilliys auto and wired the switch on the light to switch the ground on the relay on and off but there are a number of ways to do it. Don't wire it to you head light you can burn out your starter switch. If you don't want to go the relay route run a wire back to your battery with an inline fuse.
#6 (permalink) | |
#7 (permalink) |
From what I've read here, it seems power for the starter switch runs through headlight.
If so, this was brilliant <insert sarcasm> on Honda's part. If you crank the bike over with those lights on, drawing all that extra juice, you may burn out your switch. Mine is set up so I use an on/off switch to the running lights; I don't turn them on when starting the bike--only after it has been started. Seemed to me the easiest solution. For me. YMMV. If there is a problem with this idea, I'm positive someone will let me know . . . <grin>
Peace. -john ![]() ![]() It's not the bike; it's the rider. 2012 Harley-Davidson 103 cu. in. FXDF; Stage 1 modifications, Vance & Hines exhaust, Harley-Davidson security system '03 Honda 750 Shadow Spirit; '93 Yamaha 750 Virago Ride bells by old dad and Ann Last edited by Lakota; 08-07-2012 at 09:24 PM. |
#8 (permalink) |
+1, don't be that guy that thinks he doesn't need to "extra hassle and wiring" of a relay. Or you will be that guy that burns up his starter switch.
![]() Check this thread for where the book is now - it's traveling! Make sure you get your shot at it!! And check the Google Map here! The Trip map is here My VTX Garage! |
#9 (permalink) | ||
You need a wire TIGHTLY attached to the lightbar frame and then run back to an engine or frame or battry ground. Quote:
The power for the headlight goes through the start switch, so that the headlight gets turned off while cranking. That's also why a relay is needed. The headlight contacts on the start switch won't support any extra current draw, like what would happen if you just bridged the extra lights to the headlight. You didn't mention what model bike you have. Some won't handle a lot of extra wattage. The VLX is one. You need to find out what wattage the bulbs are in the bar. 2X35 (or less) should be fine. 2X55 often is too much. |
#10 (permalink) | |
So, if I wired it to the headlight with a relay in between it would work? Sent from my DROID RAZR using Motorcycle.com Free App |
