#2 (permalink) | |
B) Yes. Where did you read that ?? The purpose of chain lube is for the sprockets and rollers on the chain. It is NOT for the pins and O-ring seals......as they take care of themselves with the grease INSIDE the seals. Last edited by BrightRedVLX; 08-10-2012 at 06:59 PM. |
#4 (permalink) | |
I found that reference and it was not this forum.
#5 (permalink) |
But it WAS a self-serving statement made by a chain lube manufacturer.
There are two things that you can always believe: Anything you see on the Internet AND Any marketing claim made by a big company. You do have to be a little careful about what you use to CLEAN an O-ring chain though......as some harsh solvents can do bad things to the rings. I solve the problem easily though; I never clean mine. |
#6 (permalink) | |
Super Moderator
Stay away from using oil as a chain lube on your o-ring chain..... in fact, stay away from any lube other than BelRay "SuperClean." I've been using it for nearly 20-years, and it is by "an extreme long shot" the best chain lube on the market! Super Clean Chain Lube | Bel-Ray Company, Inc Phil
#7 (permalink) | |
I think the op is referring to what to use when cleaning the chain....certain solvents can degrade the o rings. However.....there are O ring specific lubes on the market for several reasons. One is to preserve the o ring (additives in the lube), another is the lube does not and should not penetrate the o ring, third is the o ring specific lube can be more sticky / tacky and more resistant to being thrown off at speed. Different type of chain......different type of lube.
When all think alike......no one thinks very much. |
#8 (permalink) | |
Super Moderator
Some people make way too much out of chain maintenance. Phil
![]() 1973 Yamaha RD-350 ![]() Sterling Heights, Michigan |
#9 (permalink) |
Funny, that's not what Honda says.
And it has worked fine for me for a LOT of years. Can't comment on the stuff you recommended; it might be "better". Almost anything is less messy......even if you are real careful not to put on too much oil. |
#10 (permalink) | |
Super Moderator
The problem with oil is that it doesn't last long, especially when riding in the rain; plus it flings all over and makes a mess. Modern chain lubes (like the BelRay brand) allow you to spend more time riding, less time lubing and less time cleaning "fling" off your fenders. If you don't mind pushing your bike around the driveway every 500 miles to oil the chain, then by all means; stick with the oil. If you're like me, and you'd rather ride than oil, then try the BelRay SuperClean. Phil
