coolant change - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 09-01-2012, 10:44 PM Thread Starter
hondaboi's Avatar
coolant change
Hey guys I got a 2001 spirit 750 with 21,000KM on it, I bought it with 17,000km a few months ago, I don't know when the last coolant change was, how many years or how many KM until it needs a change.
Thanks
01 Honda SS750 - Cobra pipes, drag bars, Billski tail light, cleared front turn signals, Bullet style rear signals, Granucci solo seat, Mappams forward controls, 3" spike fork extensions, 10.5" shocks, VTX headlight
hondaboi is offline
post #2 of 8 (permalink) Old 09-01-2012, 10:52 PM
bluedad's Avatar
If you don't know when the last change was, it'd be a good time to do it soon. I think the recommendation is every two yrs.
2008 HD Dyna Low Rider
2000 Kawasaki Nomad 1500
1998 Honda Shadow ACE 750
bluedad is offline
post #3 of 8 (permalink) Old 09-01-2012, 11:42 PM
It should be listed in your Owner's Manual. I have a 2009 Honda Shadow Spirit 750 and just looked up the coolant change interval. It should be changed at 8,000 miles OR every two years - which ever one comes first. Make sure you use the correct coolant too . . . not all coolants are acceptable for motorcycle use.
DRVMN is offline
post #4 of 8 (permalink) Old 09-02-2012, 03:04 AM
cza888's Avatar
That just about covers it
You may not end up where you thought you
were going, but you will always end up where you were meant to be
__________________________________________
2009 Suzuki M50
cza888 is offline
post #5 of 8 (permalink) Old 09-02-2012, 08:57 AM Thread Starter
hondaboi's Avatar
THanks guys,I'm going to do it today, I bought the coolant from honda
hondaboi is offline
post #6 of 8 (permalink) Old 09-02-2012, 06:56 PM Thread Starter
hondaboi's Avatar
So I got it changed, I'm in between the low and high on the reserve tank, do I need to buy another bottle of coolant to fill it to the upper mark? Or can I ride it how it is?
Thanks
hondaboi is offline
post #7 of 8 (permalink) Old 09-02-2012, 07:36 PM
What was the engine temp when you checked the level? When your engine is cold - the level should be at or above the low mark. The coolant will expand as the engine warms to operating temperature and then the level would be between the two marks.
I would check the recovery tank a couple more times over the next week or so as the engine warms and cools just to make sure the level is where it needs to be. If there was any air left in the cooling system, coolant from the recovery tank would be sucked back when the system cools - replacing the air and possibly lowering the coolant level in the tank.
DRVMN is offline
post #8 of 8 (permalink) Old 09-02-2012, 09:19 PM Thread Starter
hondaboi's Avatar
Out for a ride now, too dark to check I will have to tomorrow, I bleed all the air that I could out, so will have to check the reserve tank in the morning and see what the level is. Hope its good cause I really don't want to buy another bottle of the Honda HP coolant,
hondaboi is offline
