The Long Road - VT700 Rebuild and Remodel - Page 7 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-14-2012, 04:08 PM   #61 (permalink)
mattyo's Avatar
Originally Posted by luisr320 View Post
There isn't much stuff in there.
The fuel pump may be discarded if you manage to get the fuel in the carbs by gravity.
The blinkers relay may be discarded if you decide not to have blinkers. You may install led blinkers that do not require a big relay to work.
You must have the CDI because that's the only way the engine will work.
You may use air filters directly attached to the carburaters and discard the air box. That will give you a lot of space, if you have one, that is.
+1 on removing the air-filter box!
You could also get rid of the secondary fuel tank. Obviously you'll have to fill up with fuel more often but that will free up a lot of room too.
mattyo is offline   Reply With Quote
Old 11-14-2012, 10:28 PM   #62 (permalink)
Wait so how would the air filter get taken care of? Because I would most definitely be willing to do that. Not so sure about going gravity fed, and sans reserve tank would likely be a no-go.
Davidson1023 is offline   Reply With Quote
Old 11-14-2012, 10:31 PM   #63 (permalink)
And I dont have blinkers at the moment but I do intend to add some with the rebuild.. Led would be entirely viable as long as I can get it in an old school post war look!
Old 11-15-2012, 02:27 PM   #64 (permalink)
luisr320's Avatar
Look for something like this:
Or this:
It will end up like this:
Check out this post from other Forum user:
84 VT700C project bike
Old 11-15-2012, 03:15 PM   #65 (permalink)
First off, definitely going to go that route... It'll give me space for the cdi boxes at least!
Secondly I ran into this http://jbmindustries.com/KeihinVGinstructions.html
On that same thread... Do you guys think this would work as a replacement to my messed up carb?! Cause that'd be a freaking godsend!
Old 11-15-2012, 05:06 PM   #66 (permalink)
Looks like HippoDaddy an at least one other member have given them a shot? May be my best bet because 20 is a lot easier to swallow with all the other work I've got to do
Old 11-15-2012, 05:14 PM   #67 (permalink)
luisr320's Avatar
Those diaphragms are like 100US$ a pop, if ordered from the dealership. I know because I bought a pair. If I had known of the existence of that repair kit, I would have certainly tried it.
Changing the whole air intake system might force you to rejet your carbs.
Old 11-15-2012, 06:28 PM   #68 (permalink)
Secondly I ran into this Keihin 72mm diameter diaphragm Honda VT CBR Hurricane Installation
Yes they work, I looked at your pics and it looks like you have the metal slides like mine, BUT VERIFY before ordering. If they are metal slides, you will need the K-72-S diaphragms. If you need help, I can walk you through the process, or you can ship the carbs to me and I can change them for you. I need the whole carb, because the slide and diaphragms has to be installed a certain way to line up correctly.
rickou812 is offline   Reply With Quote
Old 11-15-2012, 07:08 PM   #69 (permalink)
Well I may be screwed then... They're sold out of the ones for metals
Old 11-15-2012, 07:27 PM   #70 (permalink)
luisr320's Avatar
There is one here:
Honda Vt700c Shadow 1984 Usa Carburetor Components - schematic partsfiche
This is an European store. I'm sure you can find it in the US also, maybe from the dealer.
These are 129€, almost 50% more than the VT750 ones. Ouch!!!
