Carb jet and air filter? - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 10-31-2012, 05:49 PM   #11 (permalink)
Originally Posted by Rmitch View Post
How much other modding would I have to do if I went 42 pilots? Isnt that like a stage III setup? I was just wondering, thanks
The kit you have will work fine for a Stock Bike up to modifications including aftermarket exhaust and filter. How much modding to make the $42 pilot worth while, depends on whether or not you need it now and what those mod are to be. What I'm saying is that 1 guy needs that #42 out of the showroom, the next not till he starts doing major mods. The thing about the big pilots is that 90% of the people running them don't NEED them, but it won't hurt anything and they "feel" better about it. So why argue.
Old 10-31-2012, 11:54 PM   #12 (permalink)
Scrapdog2grand's Avatar
its not nessicary, but worth it in my opinion, but you know the story behind that right? lol
But most if not all the carbjetkits.com and factory pro kits come with pilots, even the stage 1, so its entirely prefference.
1999 VLX
1998 SA750
2003 SA750
Old 11-01-2012, 09:13 AM   #13 (permalink)
Rmitch's Avatar
Ok I understand, I think I will just stick with this stage1 jet kit right now! Its funny every since someone said something about backfiring, I have been noticing backfiring when letting off the throttle! I dont know if i was just not paying that much attention before or its just getting worse! Eitherway I hope this kit fixes this problem. Thanks again for all the info and help
Rmitch is offline   Reply With Quote
Old 11-01-2012, 11:20 AM   #14 (permalink)
If its getting colder out where your at that can cause some decel pop, colder denser air will cause you to run a little leaner. you can try backing out idle mixture screws some, 1/4 turn at a time.I wouldnt go more than 3 1/2 to 3 3/4 turns out.
If that doesnt eliminate the poping, then you go up one size on the pilot jets. that will bring the screw back in and eliminate the popping on decel.
1999 VLX
1998 SA750
2003 SA750
Old 11-05-2012, 02:53 PM   #15 (permalink)
Rmitch's Avatar
Well I got the jet kit in sat and had some serous popping and I backed out mixture screw 1/4 turn and it stopped the popping! Today its about 20`cooler than sat and the dang popping is back! Are these carbs that sensitive to weather change or do I need to go higher on the jets?
Old 11-05-2012, 03:00 PM   #16 (permalink)
04LowShadow's Avatar
You will learn to find that happy medium. Your not gonna eliminate all the popping. If you do you run the risk of going to rich at Zero-part throttle input. As it has also been stated weather/air temp will play a major roll in fueling when tuning the carbs. Once you find that sweet spot leave it.
Just my .02.
04 Aero 750
Cobra HP Pro Exhaust,Wrapped
De-snorkeled,K&N AF, Dyno Jet JK
Blue Collar Bobbers 31" Drag bars and Risers, Avon Grips,Baron Tach
Goodrich Braided SS/Black Teflon front brake line, EBC HH Front brakes/EBC Rear shoes
ScootMods 4" Control Extensions
ScootWorks Front/Rear 1.5 Lowering Kit
Shaved Stock Seat (Self made)
Flush Mount Tag (Self made)
04LowShadow is offline   Reply With Quote
Old 11-05-2012, 03:19 PM   #17 (permalink)
Rmitch's Avatar
Just my .02.
Yeah thought I had a sweet spot the otherday but I guess it wasent, I will try backing out another 1/4 turn to try to get rid of as much as I can! Man I hate that popping, makes me think something is wrong with my bike! Thanks for your 2cents
Old 11-05-2012, 03:26 PM   #18 (permalink)
Mine has gotten a little more vocal as well now that we have cooled of here in FL. But I know summer time it with be gone.
And your welcome.
04 Aero 750
Old 11-05-2012, 04:04 PM   #19 (permalink)
Rmitch's Avatar
And your welcome.
Man is that ur bike? That is one Good looking bike! Did you do all those mods urself? Great job who ever did it
Old 11-05-2012, 04:06 PM   #20 (permalink)
That's mine. And yes I did all the mods my self. Thanks!
04 Aero 750
