Asked about suspension upgrades the other day ,no real results.Just thought I would pass-along some thing I did.I got a noticable change for the better by messing with tire pressure.I picked the bike up from the dealer so (assumed) that tire pressure was correct.Read owners manual and it says 29 pounds in front and rear with a few more in rear if loaded or if you weigh over 200lbs.Well there was about 32 lbs front and rear,so I reduced front to 29 and increased rear to 34.The bike handled much better and the rear shock is still set at #2 preload.Trying to get a hold of pin spanner to toy with preload but the air pressure fix was a lot cheaper than new fork springs and shocks ( for a new bike?! )
#2 (permalink) | |
![]() Keep the rubber side down ... unless of course you have a rubber head! My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf |
#4 (permalink) |
Also, worse comes to worse use a strap-type oil filter wrench.
#6 (permalink) |
Run tire pressure at what the manufacturer of the vehicle calls for, not the tire manufacturer. The tire pressure specs on the sidewall are a maximum recommended pressure for the tire only, not the vehicle.
