Fuel leak after valve adjustment - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-07-2012, 03:51 PM   #1 (permalink)
Default Fuel leak after valve adjustment
I recently adjusted the valves on my 09 vt750c2. Took tank off to do the repair. While tank was off I turned it every which direction including upside down because I was installing LED's. After being re-installed I had drops of fuel leaking from the main line out of the petcock. I replaced the spring clamp with a regular hose clamp and it still leaked albeit a lot slower. I'm afraid to crank down anymore on the clamp.
It's leaking right at the hose and thinking maybe it's damaged. Was thinking about replacing the line and both spring clamps. Any other suggestions? Or anyone have a smilar problem?
2009 Shadow Spirit VT750C2
2003 Harley Fatboy FLSTI
1985 Rebel CMX250C-Sold
DarkSpirit750 is offline   Reply With Quote
Old 11-07-2012, 03:58 PM   #2 (permalink)
Those hoses are intended to last forever or until touched by human hands.
Replace them!
Rock is offline   Reply With Quote
Old 11-07-2012, 04:27 PM   #3 (permalink)
Replace them!
Kinda what I was thinking.
Old 11-07-2012, 06:04 PM   #4 (permalink)
John Hopkins's Avatar
I had the same problem on my 1992 VT1100 and I managed to patch it up by cutting about an inch off the hose..but I will still have to order another one when I get time..
John.
Old 11-07-2012, 06:09 PM   #5 (permalink)
DRVMN's Avatar
Wondering if you have a cut or slice in the hose . . . did any fuel leak out of the petcock when the tank was off? That would eliminate the tank/petcock as the source of the leak. At least fuel line is inexpensive to replace. Good luck. I adjusted my valves earlier this Spring. Easy job but very time consuming - especially removing the rear valve cover.
2009 Honda Shadow Spirit 750
-Mustang Seat & Backrest
-Memphis Shades Windshield & Lowers
-Saddlemen Highwayman Saddlebags
-National Cycle Paladin Highway Bars
-Show Chrome Accessories Radiator Cover
-Kuryakyn ISO Pegs (Driver & Passenger)
-Kuryakyn ISO Grips
-Honda Luggage Rack and Sissybar
-Honda Saddlebag Supports
DRVMN is offline   Reply With Quote
