Left Me Stranded - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-09-2012, 07:18 PM   #1 (permalink)
Unhappy Left Me Stranded
So, my 2004 Sabre finally let me down. Rode it home from work (approx. 35 miles) and everything was fine. Stopped at the Post Office before the house and when I went to start it the lights came on and upon press of the start button one single click from under the seat and the lights all went out. WTF?!?!?! So, I turned it off, pulled the key and tried again. Exact same thing. Ok, lets try this a third time but this time the lights wouldn't even come on with the key turned on. Crap. So I pushed it home (2 blocks up one hell of a hill) and began the troubleshooting.
Mulitmeter read 12.5 with the key off and still wouldn't start. Put the battery charger on it to jump it and it jumped and fired right up. Pulled the charger and the bike began to idle like crap (wouldn't rev, and lights were dimming when trying to rev it.). So, I pulled the battery and charged it for a couple hours and re-installed it. Bike fired right up and ran like a champ. Checked voltage while idling and while revving (13.6 idle, 14.8 revved) and compared it to the charge just off the charger (15.2ish). Turned on hi-beams, turn signals, brake lights and the battery voltage didnt drop a whole lot.
So, after all that I have a couple of questions. First, how could my battery be at 12.5 and not start the bike? How could I be riding just fine for 35 miles and have it off for 10 minutes at most and then have a no-start condition? Any suggestions/comments? Thanks
2004 Shadow Sabre
Nick
silvercrew is offline   Reply With Quote
Old 11-09-2012, 07:30 PM   #2 (permalink)
justinmahn's Avatar
Crusty connection somewhere. It kinda just creeps up and ambushes you.
Old 11-09-2012, 07:37 PM   #3 (permalink)
Where would be the most likely offenders? Overall the condition of this bike is near flawless (or as near flawless as a 21k 8yr old ride can be). Thanks.
2004 Shadow Sabre
Nick
Old 11-09-2012, 07:43 PM   #4 (permalink)
bad battery... the voltage does not matter in this situation... it needs to be load tested. i have tested many batteries with a "full charge" but when loaded, they flat line..
1999 1100 Aero, ALL STOCK except for Tsukayu hard bags and Memphis shades Batwing fairing.
bigblueskies98 is offline   Reply With Quote
Old 11-09-2012, 07:44 PM   #5 (permalink)
justinmahn's Avatar
You might have already gotten it when you charged the battery. Other areas might be ground wires to the engine and frame. Alternator connections (or whatever it's called). I think that covers the charging system. I'm sure there are more knowledgeable people here than me.
Old 11-09-2012, 07:46 PM   #6 (permalink)
justinmahn's Avatar
@big, someone recently suggested to monitor the voltage when cranking. If it drops below 10v then do we replace?
Old 11-09-2012, 09:05 PM   #7 (permalink)
You may have answered your own question. You pulled the battery and charged it and everything is fine. If you had a loose or corroded connection at the battery it would cause the problem you were having and by removing and reinstalling you corrected the problem. I would suggest disconnecting the battery cables, cleaning the cables and battery posts good and reconnect them.
dgraves49 is offline   Reply With Quote
Old 11-09-2012, 09:26 PM   #8 (permalink)
Voltage does not equal stored/available energy. Bad Battery. Replace.
jewellfish is offline   Reply With Quote
Old 11-10-2012, 05:06 AM   #9 (permalink)
Have the battery load tested before you replaced it. A bad battery connection can cause the same thing. I just had it happen on my bike with a fairly new battery.
Auto parts stores will load test it free of charge.
Schattenreiter is online now   Reply With Quote
Old 11-10-2012, 05:55 AM   #10 (permalink)
John Hopkins's Avatar
Yes it means you have one dead cell.
John.
