Universal fuel filter... - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 6 (permalink) Old 11-11-2012, 04:38 PM Thread Starter
SuperiorKolours's Avatar
Has anyone ever tried using a universal fuel filter from the auto parts store instead of the oem? Price difference is close to $20. Is it even possible?
SuperiorKolours is offline
post #2 of 6 (permalink) Old 11-11-2012, 05:14 PM
Spool's Avatar
I've used one. As long as you get one that uses the same diameter hose and it fits where you need to put it there should be no problem.
2002 Shadow Spirit 1100
Spool is offline
post #3 of 6 (permalink) Old 11-11-2012, 06:05 PM Thread Starter
thanks. Now how do I figure out what diameter it is?
post #4 of 6 (permalink) Old 11-11-2012, 06:26 PM
Lakota's Avatar
If you want to be certain, pull the filter and take it to the store. Should be no big deal.
Sent from my iPhone using Motorcycle.com App
Peace.
-john
It's not the bike; it's the rider.
2012 Harley-Davidson 103 cu. in. FXDF; Stage 1 modifications, Vance & Hines exhaust, Harley-Davidson security system
'03 Honda 750 Shadow Spirit; '93 Yamaha 750 Virago
Ride bells by old dad and Ann
Lakota is offline
post #5 of 6 (permalink) Old 11-11-2012, 06:48 PM
I did on an 88 800 I bought for my daughter. I tried 3 different ones before I gave up and put out the cash for the OEM filter. The filter mounts in such a tight hole that I couldn't get an aftermarket filter that would work. If the diameter of the connections was right the body of the filter was too large.
If you can find one that fits and has the right size connections there is no reason it won't work. If you can't fit it where it is now you might move it to a different location and replumb it.
Schattenreiter is offline
post #6 of 6 (permalink) Old 11-11-2012, 11:19 PM
razor78016's Avatar
Send a message via AIM to razor78016 Send a message via Yahoo to razor78016 Send a message via Skype™ to razor78016
PM sent.
1985 VT700C Vid http://www.youtube.com/watch?v=gHNQqIJhuD0&feature=plcp Updated: Relocated clutch lever. Vindicator bars by R.O.C.
razor78016 is offline
