Fuel issue? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-12-2012, 12:27 AM   #1 (permalink)
Default Fuel issue?
Need some good advice. Twice now my 07 Aero has acted like its out of fuel. Both times it happened about 100 miles into a tank of fuel. Pulled over, flipped it to reserve, bike fires right up. Go to the gas station and it only takes 2.7 gallons which means I have a gallon left. After I fill it up, flip it back to main tank, it fires up and rides fine. Also, after I got to the gas station I shut it down, flipp
Sent from my PC36100 using Motorcycle.com Free App
07 Aero 750
Mustang seat
M/C Enterprises floorboards
Heel/toe shifter
DarkAero is offline   Reply With Quote
Old 11-12-2012, 12:31 AM   #2 (permalink)
Flipped it back to main before I put fuel in and it fired right up. When it first happened it wouldn't start until I switched to reserve. But after riding a couple miles it worked on the main tank. I haves owned the bike for 2 weeks and am very green at doing my own wrenching. What should I start checking first?
07 Aero 750
Mustang seat
Heel/toe shifter
Old 11-12-2012, 06:36 AM   #3 (permalink)
04LowShadow's Avatar
Thats how many gal's I use and I get 117 miles before switching to res. Yours seems a little low but not to be alarmed. Just sounds like you not getting very good MPG.
04 Aero 750
Cobra HP Pro Exhaust,Wrapped
De-snorkeled,K&N AF, Dyno Jet JK
Blue Collar Bobbers 31" Drag bars and Risers, Avon Grips,Baron Tach
Goodrich Braided SS/Black Teflon front brake line, EBC HH Front brakes/EBC Rear shoes
ScootMods 4" Control Extensions
ScootWorks Front/Rear 1.5 Lowering Kit
Shaved Stock Seat (Self made)
Flush Mount Tag (Self made)
04LowShadow is offline   Reply With Quote
Old 11-12-2012, 07:12 AM   #4 (permalink)
When you removed the gas cap, did it release pressure. Wondering if it mght be a clogged vent.
2006 Honda Sabre
Old 11-12-2012, 08:31 AM   #5 (permalink)
Sometimes fuel pumps can get weak and refuse to empty the tank. When my pump failed this way, it would run great until about 89 miles, then if I ran it hard it would sputter out, but it would still run. There is a flow test to see if your pump is working correctly.
01 Sabre Dave
08 V-Star 1300T Sarah
verdeva is offline   Reply With Quote
Old 11-12-2012, 10:36 AM   #6 (permalink)
Same is happening to me. I am also getting what I think is terrible mpg. I do all stop and go driving and refill when I get to 100 miles.
laughinglion is offline   Reply With Quote
Old 11-12-2012, 10:46 AM   #7 (permalink)
I would agree with you about the MPG except there is still a gallon in left in the tank when I fill up. Does that happen to you also?
07 Aero 750
Mustang seat
Heel/toe shifter
Old 11-12-2012, 10:49 AM   #8 (permalink)
I will pop the cap if it happens again and see if it fires up after that. How do you fix a clogged vent? Sounds like I news to have ny fuel pump flow tested as well. Thanks for the advice on that.
07 Aero 750
Mustang seat
Heel/toe shifter
Old 11-12-2012, 10:50 AM   #9 (permalink)
All my driving is stop and go also
07 Aero 750
Mustang seat
Heel/toe shifter
Old 11-12-2012, 10:54 AM   #10 (permalink)
I should also mention that I have only had the bike for 2 weeks and it only had 1641 miles on it when I bought it.
07 Aero 750
Mustang seat
Heel/toe shifter
