2007 Spirit 1100 issues - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 16 (permalink) Old 11-12-2012, 11:03 PM
Dauntae's Avatar
The milage has nothing at all to do with fouled carbs, it's how long it sat with gas in the carbs that foul them, could be a 83 with 10 miles but if it was put away and sat for all those years the gas dries out and leaves a varnish in the carb and blocks the jets, and that's what is being cleaned out in most cases, how many miles on doesn't matter at all on if the carbs need cleaning.
Dauntae
2001 Shadow Spirit 1100 Cobra highway bars Kury ISO grips w custom weighted bar ends ,a VTX headlight and Kury Large ISO pegs but the best addition, Riding bell from Kathy M
I laugh in the face of danger, then I hide until it goes away
The book of John Hopkins map
http://www.travellerspoint.com/membe.../tripid/365293
Dauntae is offline
post #12 of 16 (permalink) Old 11-13-2012, 08:49 PM Thread Starter
Thanks D. Short of removing the carbs, would a fuel injection cleaner help?
laughinglion is offline
post #13 of 16 (permalink) Old 11-13-2012, 08:54 PM
Dauntae's Avatar
Depending on how bad there blocked up, a lot of people use seafoam with good results, run a few tanks worth and it may clear it up at worst it won't do it but won't make it any worst. I use seafoam for winter storage also as it is a gas stabilizer also.
Dauntae
Dauntae is offline
post #14 of 16 (permalink) Old 11-16-2012, 09:50 PM Thread Starter
Update: tires both in balance. Carbs were in sync. The knock/ping isn't "anything abnormal" for the vt1100 ( I did read of this on other posts). The only rattle was heat shield which they tightened. All fluids were pristine, as should be for only 1400 miles.
It wheels are in balance an got no shim. However, they did ask if I wanted to try ltb ( liquid tire balance). I declined.
At this point I am going to chalk it up to being a newb (although the technically I am not. Just got back into riding after 15 years).
post #15 of 16 (permalink) Old 11-16-2012, 10:53 PM
Try a few rounds of seafoam, snug up the carb boots and make yourself a sync tool. Drop to 87 octane (mine gets horrible mileage on 94), and keep the revs up as you ride ... don't lug it. Check the air filter as well especially if it was storage as some critters may have had some fun in there.
These engines usually run strong and are as reliable as Sunday.
Don't forget to enjoy! It's a great ride!
2006 Shadow Spirit 1100 - sold May 6, 2016
2011 Victory Cross Country
Thanks
Vaughn
vgreid is offline
post #16 of 16 (permalink) Old 11-17-2012, 01:25 PM
Earthling789's Avatar
Squirrely rear-end? Have you checked the pre-load on the shocks? They may be set too low, or one could be set higher than the other...
I had a similar issue on my VT700... found one to be set at 5, and the other was at 2 (doubt the previous owner ever noticed), which caused mixed compression in curves and made the rear-end feel like it was all over the place, especially on right-hand curves/turns.
On my Sabre, the PO had the pre-load too high (on #5), which caused excess stiffness, which translated into rear-end "bounce" in the curves and over rough roads... really an unnerving feeling. Too low will create an odd feeling too... too much compression and you'll feel like you're squishing into the curve too hard, which is also a rear-end wobble feeling.
I'm 165-lbs and run my VT1100 on #2 for one-up riding... #3 for two-up or loaded with touring bags. How you set yours will be trial and error to find what "feels" right for you! Start out by setting them on #1 and take a ride... run the same road on #2, then #3, etc.... when you find the right spot, you'll know it... the bike will feel better in the curves (no more loose rear-end)! Just something to check...
Oh, and tire pressure will also affect the handling... Sorry, just gave you one more thing to think about
Current -
2002 VT1100C2 Sabre
1985 VT700C Shadow
1999 CB750 NightHawk (son's ride)
"The Hardest Part About a Zombie Apocalypse, Will Be Pretending I'm Not Excited"
"I'm not behind you, I'm 21,565 miles in front of you, and about to lap you again!"
Earthling789 is offline
