#31 (permalink) | |
Steve G. North Carolina 2006 Vlx Deluxe ![]() When I grow up......ahh hell I ain't plannin to do that! |
#32 (permalink) |
Those crush gaskets get dirty and look like the rest of your exhaust port, I bet they're there.
As for your smoking, here's my guess: You went down on the pipes and loosened them, coolant poured all over the motor and ran down inside the pipes where it settled until they got hot enough to boil it. If the bike was actually kicking water out the pipes, if your motor was eating that much coolant, I don't think it would run. Hope that's the case anyway. If you indeed do not have crush gaskets in there then that would back up my 'coolant getting into the pipes' theory. |
#33 (permalink) | |
Now please don't get me wrong, I'm all for suggestions but seriously ? Bugger me. if the OP posts that his loosened pipes ingested coolant while the bike was down I'll eat my crash helmet. Chris. |
#34 (permalink) |
ok well i looked at it more closely and i definitely did not have crush gaskets. I did install some and now its all back together working beautifully. Even sounds better for some reason. Now all i have to do is sync the carbs (waiting on a part), get the dent out of my tank (going to take that to a body shop)
Thanks guys for your help
1984 Honda Shadow VT500c |
#35 (permalink) |
So just an update on this. I am 90% sure that a head gasket has blown or maybe the fall jarred it enough to loosen the top part of the cylinder. While I haven't done a compression test or any other tests that I have looked up online , like the blue fluid or air compressor tests. I am getting excessive condensation and still while smelling smoke.
I am not going to take apart the engine. I can do pretty much anything else on a cycle or car. Just don't feel comfortable taking apart the cylinder because I would guess, i would miss something like not tightening the screws in the right order or with the right amount of torque I give up and I am just going to take it to my mechanic. I appreciate all your responses thus far.
#37 (permalink) |
You can get an entire, low mileage engine from eBay for sometimes $500 - $600 shipped. You can do an engine swap fairly easy. Just something to think about.
