Problems... - Page 4 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-29-2012, 08:39 PM   #31 (permalink)
SuperiorKolours's Avatar
Originally Posted by SkullCrusher View Post
Run it with the tank open.
Tanks has to breath in to let gas out. Plugged tank breather will cause vacuum in the tank to prevent gas from flowing. Also, when it heats up, bogs and dies open the bowl drains and see if its getting gas. Bogging out means its either starving or choking.
Hmm good idea, thanks.
SuperiorKolours is offline   Reply With Quote
Old 11-30-2012, 01:31 PM   #32 (permalink)
There's only 1 place all these problems can happen thats in the cylinder. If your blowing white or blue smoke it's all happening in your cylinder. If you have gas in your oil its happening in the cylinder. All these problems indicate a blown head gasket or rings or valve seals depending which one or combination of is happening. Could be a crack some where too. So you need to clear up what you see then we can help you. The not starting might be low compression again in the cylinder. Doing a compression test will eleminate or confirm that.
vonh is offline   Reply With Quote
Old 11-30-2012, 03:45 PM   #33 (permalink)
Scaredofmyownshadow's Avatar
The gas in the oil is there because he rode it home on one cylinder. The carb was dumping gas in as it was supposed to do, but there was no fire. Dump a bunch of gas with no spark and you will have that.
Scaredofmyownshadow is online now   Reply With Quote
Old 11-30-2012, 04:18 PM   #34 (permalink)
I changed the oil though.
Sent from my PC36100 using Motorcycle.com Free App
Old 11-30-2012, 06:31 PM   #35 (permalink)
04LowShadow's Avatar
What ever you do, do one thing at a time. If you try to fix to many things at once and it goes south you wont know what cause the problem to get worse.
If you blew a head gasket you would know it. Blue or white smoke constantly. At idle and while cruising. If there is water in the oil or vis versa the dip stick would look like mud and or you coolant tank would look the same.
Im sorry I dont have any ideas as to where to start other than back track your steps when it went south and began to run like crap. Start at that point.
04 Aero 750
Cobra HP Pro Exhaust,Wrapped
De-snorkeled,K&N AF, Dyno Jet JK
Blue Collar Bobbers 31" Drag bars and Risers, Avon Grips,Baron Tach
Goodrich Braided SS/Black Teflon front brake line, EBC HH Front brakes/EBC Rear shoes
ScootMods 4" Control Extensions
ScootWorks Front/Rear 1.5 Lowering Kit
Shaved Stock Seat (Self made)
Flush Mount Tag (Self made)
04LowShadow is offline   Reply With Quote
Old 12-02-2012, 08:18 PM   #36 (permalink)
Default Update
Ok so I did a compression test with a cold engine. Does it have to be at normal running temp. to expose a leak? Front was 160 psi rear was 150 psi. No drop in pressure over a period of 5 minutes in either cylinder.
Hmm, now what?
Should I still do a leak down test?
Old 12-02-2012, 08:35 PM   #37 (permalink)
I just talked to my buddy, he said he was having the same problem on a Virago and it turned out to be the CDI box. Hmm
Old 12-02-2012, 09:18 PM   #38 (permalink)
Found this on another forum...
"97' adventurer stops running after reaching running temp. When starting for the 1st time after overnight sit the bike starts first hit of starter button and runs normal until running temp is reached then shuts off like turning off the key switch, at this time the motor will crank but will not start. After a timely wait of ten minute or so it will start, run normal then die out, running time is shorter than the first. It appears the bike has to cool down to get it started again.This is my 1st major problem with the bike it has been very dependable since new. In the forum I've read about the coils but not much about the igniter or igniter pick up. When going bad what kind of problems will they cause? The igniter or (computer i was told by the triumph dealer )cost $700 with tax, thats very pricey for such a small board. Anyway any input is appreciated.......Today was the first chance to work on the bike. The ignition pick up was bad. The measured resistance was perfect until motor was at running temperature then the circuit opened shutting off the motor. I was lucky the dealer had one in stock for 59.95 and the gasket for 5.99. Its back to business as usual. Thanks to the guys who replied."
This might be the problem I am having...
Old 12-02-2012, 09:46 PM   #39 (permalink)
John Hopkins's Avatar
Well done, that was a difficult thing to find, so if you can do it without dislocating your shoulder...Give yourself a pat on the back..
John.
Old 12-02-2012, 09:56 PM   #40 (permalink)
John.
No I didnt fix my bike yet, I just found that and quoted it from another forum. Its the same problem I am having, so it might be that...
