My First Oil Change - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-15-2012, 07:27 PM   #1 (permalink)
Bobolto's Avatar
Default My First Oil Change
Did my first oil and filter change today and ended up using the full 3 quarts.
Manual calls for 2.7 Quarts 2011 Honda Shadow Aero VT750C
I put 2.7 in and the dipstick still wasnt showing full so I added a bit more
and it still wasn't there. That last quart only had about a cup left in it so I just emptied it.
Checked the oil and it was perfect full.
btw, each time I checked it I made sure the bike was level, not screwing in the dipstick. my method was to clean the dipstick, place it back in the hole (not threaded in), stand the bike up straight, put the bike back on the stand, pull dipstick and check.
I know this is probably a lame question but should I worry that I added too much oil???
Even if lets say it showed full at 2.7 quarts, would that .3 quart really make a difference in terms of too much oil?
thanks
Bobolto is offline   Reply With Quote
Old 11-15-2012, 07:34 PM   #2 (permalink)
DRVMN's Avatar
I just changed my oil last weekend - 2009 Honda Shadow Spirit 750 and found that I used a couple more ounces than the 2.7 quarts listed. Checked the oil with the bike upright, did not screw the dipstick in, etc.
-Mustang Seat & Backrest
-Memphis Shades Windshield & Lowers
-Saddlemen Highwayman Saddlebags
-National Cycle Paladin Highway Bars
-Show Chrome Accessories Radiator Cover
-Kuryakyn ISO Pegs (Driver & Passenger)
-Kuryakyn ISO Grips
-Honda Luggage Rack and Sissybar
-Honda Saddlebag Supports
DRVMN is offline   Reply With Quote
Old 11-15-2012, 07:38 PM   #3 (permalink)
MOFO YO's Avatar
Did you change the filter also ??? then run her and check the oil before you added the other .3 quart ???
MOFO YO is offline   Reply With Quote
Old 11-15-2012, 07:41 PM   #4 (permalink)
Bobolto's Avatar
Yes, I did a Filter too.
and Yes I ran the bike for a bit and let it sit a bit between that first check.
I have a full 3 quarts in my VT750 and the oil level shows full , where it was when I had checked the oil before changing it.
I used 10W 40 too
should I worry about it?
Old 11-15-2012, 08:29 PM   #5 (permalink)
SuperiorKolours's Avatar
Why are you guys not screwing the dipstick in?
Sent from my PC36100 using Motorcycle.com Free App
SuperiorKolours is offline   Reply With Quote
Old 11-15-2012, 08:37 PM   #6 (permalink)
Super Moderator
old dad's Avatar
You don't screw in the dip stick to check the oil.
2006 vlx
Old 11-15-2012, 08:41 PM   #7 (permalink)
wing_rider's Avatar
well because to check the oil level you dont need to.
wing_rider is offline   Reply With Quote
Old 11-15-2012, 09:09 PM   #8 (permalink)
El Fenix's Avatar
Your in bonham? We have to meet up. I was out there at Shumardis for a ride a few weeks back. PM me your info. I'm on twtex also.
El Fenix is offline   Reply With Quote
Old 11-15-2012, 10:05 PM   #9 (permalink)
MOFO YO's Avatar
I used 10W 40 too
No dont worry .3 is not gonna do any harm..you checked it the right way..
Old 11-15-2012, 10:28 PM   #10 (permalink)
Bobolto's Avatar
Ok Good thanks Man.
btw I found the perfect wrench to get that Oil drain plug off without
raising the bike.
17mm Honda Wrench 89218-431-670 perfect size tool I got it on ebay used
for $6.00 it was 1 of 3 small wrenches i bought to complete my bikes tool kit.
Thanks
