Where does this hose belong? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-17-2012, 12:46 PM   #1 (permalink)
Default Where does this hose belong?
I was planning on changing my bikes oil today but I noticed this hose hanging lose. I don't know what it does or why its unconnected. The top looks like its connected somewhere around the air filter. Does anyone know what this hose is? Or where is should be connected at the bottom? Thanks
Where does this hose belong?-photo1.jpg   Where does this hose belong?-photo2.jpg
blaubne is offline   Reply With Quote
Old 11-17-2012, 01:02 PM   #2 (permalink)
Geaux's Avatar
Might be the battery vent tube.
Sent from my ADR6350 using Motorcycle.com Free App
Geaux is online now   Reply With Quote
Old 11-17-2012, 01:02 PM   #3 (permalink)
Kitulu's Avatar
Could be the overflow tube from the fuel tank. If it is, it should be connected on the right rear underside of the tank and routed behind the engine, coming out by the coolant overflow.
Sent from my DROID RAZR using Motorcycle.com Free App
Kitulu is offline   Reply With Quote
Old 11-17-2012, 01:23 PM   #4 (permalink)
Earthling789's Avatar
It should be there... actually, more than one tube may be peeking out from under your bike... (depending on bike)... Looks like the one in your picture is the radiator overflow tube.
  • Battery (if non AGM battery) will have a vent/boil-over tube which drains below the bike to prevent acid from getting onto the frame or other parts of the bike.
  • The radiator over-flow has a vent/drain tube to keep coolant draining below the bike.
  • And some, like my '85, even have an air-box or crankcase breather drain tube (but it should have a cap over it) to allow any moisture getting into the air-box or crankcase to drain. To drain it, just pull the cap and let the gunk out... replace the cap to prevent unfiltered air from being sucked up.
  • If you have a CA model bike, the EEC valve will have a vent-tube, and possibly a drain tube as well, which should be visible peeking out under the frame.
Current -
2002 VT1100C2 Sabre
1985 VT700C Shadow
1999 CB750 NightHawk (son's ride)
"The Hardest Part About a Zombie Apocalypse, Will Be Pretending I'm Not Excited"
Earthling789 is online now   Reply With Quote
Old 11-17-2012, 01:29 PM   #5 (permalink)
Sorry I should have clarified my model. It's a 2007 VT750C2. I just never noticed it dangling there before and I've owned the bike for 1 year. Any suggestions to nail down exactly what it is?
Old 11-17-2012, 03:09 PM   #6 (permalink)
justinmahn's Avatar
My suggestion is to get a Honda shop manual and match it to a hose diagram. Sounds like you're curious enough to really start learning about how the bike works.
Sent from my MB886 using Motorcycle.com Free App
Old 11-17-2012, 04:46 PM   #7 (permalink)
5ft2's Avatar
I would guess that the previous owner got tired of draining oil out of the airbox and replaced the closed-end drain tube on the bottom of the back side (engine side of the airbox) with a longer overflow tube.
When you ride the bike at higher speeds the oil can expand to the point where it would cause too much pressure/volume in the case. In order to relieve the excess volume/pressure, it will vent into the airbox. The original closed end tube is clear do that you can see when it is full of oil and know that you will need to drain your airbox.
Here is a photo of mine. It's hard to see but you can just make our the crimped end of the hose next to the cylinder on the right. And yeah, mine has oil in it
5ft2
With Eyes of Blue
'06 Honda Shadow Aero
5ft2 is offline   Reply With Quote
Old 11-20-2012, 02:20 AM   #8 (permalink)
luvnrocs's Avatar
It's definitely the fuel vent and the end under the chassis should be just like it is in your pic. I actually posted the same question earlier this year when I noticed mine after having the bike for a month or so.
Welcome to the newbie club.
2007 Honda Shadow Spirit 750DC
w/ Cobra Drag Pipes, Kuryakyn Transformer Grips
luvnrocs is offline   Reply With Quote
