If you aren't lucky enough to have a garage kept bike... - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-17-2012, 08:25 PM   #11 (permalink)
Super Moderator
old dad's Avatar
1/2 can is way too much for one tank of gas.
2006 vlx
Old 11-17-2012, 08:33 PM   #12 (permalink)
Geaux's Avatar
1oz per gallon.
Sent from my ADR6350 using Motorcycle.com Free App
Geaux is online now   Reply With Quote
Old 11-18-2012, 12:05 AM   #13 (permalink)
shadowmaker07's Avatar
Considering the heaviness of those little cans, there was probably more like 1/2 a cup left from earlier this year when she kept doing this and something ended up being clogged. With 99 miles on the trip ODO (and I normally get 125-150 per tank), there shouldn't be that much fuel in it but I could see it down in there as I was pouring it in.
shadowmaker07 is offline   Reply With Quote
Old 11-18-2012, 02:25 AM   #14 (permalink)
Originally Posted by dorfman17 View Post
I go full choke for about one min then lower it as far as she will stay running. Usually no problems even in the low thirties.
^^+1 Has worked so far down to about 44 degrees or so. It can get chilly overnight, even in Phoenix.
My timing is less precise, hi idle until I get a my balaclava, helmet and glasses on. Drop it by about half while I'm checking the turn signals, brake lights, etc. Something just above idle to get me the first few blocks, then all the way in for the rest of the commute.
I use Lucas Deep Clean, about the same amount 1 oz per tank. Only occasionally.
Kokopelli
2008 Roketa MC-74-150K (Sold 2012)
2007 Shadow Aero
Kuryakyn ISO-Grips, Stiletto End Caps, Dually ISO-Pegs, Master Cylinder Cover
Show Chrome Accessories Air Filter Cover
Ride Bells thanks to my Better Half
kokopellioh is online now   Reply With Quote
Old 11-18-2012, 08:25 AM   #15 (permalink)
04LowShadow's Avatar
Originally Posted by Geaux View Post
1oz per gallon.
Exactly!!!!!
04 Aero 750
Cobra HP Pro Exhaust,Wrapped
De-snorkeled,K&N AF, Dyno Jet JK
Blue Collar Bobbers 31" Drag bars and Risers, Avon Grips,Baron Tach
Goodrich Braided SS/Black Teflon front brake line, EBC HH Front brakes/EBC Rear shoes
ScootMods 4" Control Extensions
ScootWorks Front/Rear 1.5 Lowering Kit
Shaved Stock Seat (Self made)
Flush Mount Tag (Self made)
04LowShadow is offline   Reply With Quote
Old 11-18-2012, 05:35 PM   #16 (permalink)
She's fine. Just seems to prefer a longer choke than others apparently.
I guess it was just the variation of temps the past 2 and a half months of sitting there. Does still seem a little "throaty" in the pipe but could just be my nerves too.
Old 11-18-2012, 07:14 PM   #17 (permalink)
C.W.'s Avatar
Respectfully, next time it has to sit for a while, fill it with FRESH gas, add some fuel stabilizer, and run it down into the carb(s). It'll be worth it in the long run. I've read too many threads about bikes that have sat for a long period of time having all sorts of gas/carb problems.
Good luck, C.W.
C.W. is offline   Reply With Quote
