If you aren't lucky enough to have a garage kept bike... - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-17-2012, 04:46 PM   #1 (permalink)
shadowmaker07's Avatar
Default If you aren't lucky enough to have a garage kept bike...
How long do you choke and run your bike before taking off?
Mine has been sitting since Aug. 28, only started one time and dang, she is cold and sluggish!! Or is there something I should do to clear her throat from the long sit?
Why yes, I do happen to like Purple.
What was your first clue?
They say laughter is the best medicine. Unless you are laughing ALL the time, then you probably need some REAL medicine, you freak.
shadowmaker07 is offline   Reply With Quote
Old 11-17-2012, 05:44 PM   #2 (permalink)
CrazyDave's Avatar
You can do this
How to use SeaFoam to clean your Engine - The RIGHT way!
or you can just throw some in the gas tank and take it for a run.
Facebook page
CrazyDave is offline   Reply With Quote
Old 11-17-2012, 05:44 PM   #3 (permalink)
I go full choke for about one min then lower it as far as she will stay running. Usually no problems even in the low thirties.
2001 spirit 1100 , vance and hines long shots, , a few other small mods. Now also with a mustang seat
dorfman17 is online now   Reply With Quote
Old 11-17-2012, 06:13 PM   #4 (permalink)
Originally Posted by CrazyDave View Post
You can do this
I poured in about half a can and went about 3 miles and it is still bleh! Every single stop, she is wanting to cut out on me resulting in my riding the clutch to keep from popping it and dumping her. As well as rolling the throttle more than I normally would.
Old 11-17-2012, 06:48 PM   #5 (permalink)
Doesn't sound like a cold engine problem to me. After 3 miles, your bike should be warm enough to do anything it needs to do...
1996 Honda Shadow VLX 600
Red/Black
kacealraid is offline   Reply With Quote
Old 11-17-2012, 07:01 PM   #6 (permalink)
CrazyDave's Avatar
try at least 20 miles on a road with few stops and lots of room to stretch..
Facebook page
Old 11-17-2012, 07:15 PM   #7 (permalink)
Will do tomorrow then. Had to stick around for someone picking up last roommates entertainment center.
Old 11-17-2012, 07:18 PM   #8 (permalink)
Bens06Sabre's Avatar
if its really bad might have to run a tank of fuel thru her to notice a difference, I swear by sea foam, to help keep fuel system clean, or clean it to a point, its not a mirricale cure but close
Bens06Sabre is offline   Reply With Quote
Old 11-17-2012, 07:20 PM   #9 (permalink)
Sounds like water in the float bowls to me. I would put in freash gas and drain the bowls 4 or five times. Only drain when the engine is cooled off or attach a drain hose so no fuel hits the engine.
1rusty1 is offline   Reply With Quote
Old 11-17-2012, 07:21 PM   #10 (permalink)
Two things...The above Seafoam article is a for car...Putting a half of can in your gas tank...your not going to get any results in 3 miles...Run the crap out of it...refill and put
the other half in and again run her...it may take several cans to clean things up...it is
pretty good stuff...but it takes way more than a few miles for it to do its job...
Good Luck
finjoey is offline   Reply With Quote
