fork oil - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 31 (permalink) Old 11-20-2012, 12:26 PM Thread Starter
fork oil
I am about to buy fork oil and drain my old stuff out but I dont know what to get....
My manual all it specifies is "ATF" fork oil. which tells me nothing. doesn't tell me what weight or anything. Any suggestions?
1984 Honda Shadow VT500c
computerfixit524 is offline
post #2 of 31 (permalink) Old 11-20-2012, 12:34 PM
Automatic transmission fluid?
http://www.valkyrieforum.com/bbs/ind...?topic=38894.0
2005 Honda Shadow Spirit VT750DCB
AnthonyZ is offline
post #3 of 31 (permalink) Old 11-20-2012, 12:44 PM Thread Starter
well i know what it stands for ;it just doesnt tell me the weight etc of what oil i need for the forks
post #4 of 31 (permalink) Old 11-20-2012, 12:47 PM
This site says that SAE 10wt can be used where SAE 10W20, ATF, ATF-D, ATF-D2 or D2 oils are specified by the manufacturer
Silkolene Fork Oil - Street Motorcycle - Motorcycle Superstore
AnthonyZ is offline
post #5 of 31 (permalink) Old 11-20-2012, 01:08 PM Thread Starter
interesting , thank you
post #6 of 31 (permalink) Old 11-20-2012, 01:08 PM
Check for sure, but you need only about 1 qt of fork oil.
The price of genuine Honda fork oil at my local dealer is about $8
and that seems cheap enough for me since it will be several years before I need to change oil again.
Happy Thanksgiving,
1983 Nighthawk 650
1989 VTR250
1985 Sabre 700 - - Sold
1983 Shadow 500 - - Sold
2006 Ninja 500- - - - Sold
ExTex is offline
post #7 of 31 (permalink) Old 11-20-2012, 01:17 PM
Go with 15 or 20 weight forkoil instead of the 8 or 10 thats spec'd. It will firm up the front end and limit diving under breaking.
jpr1968 is offline
post #8 of 31 (permalink) Old 11-20-2012, 02:06 PM
MinnesotaGreg's Avatar
The weight of the oil changes greatly over temp ranges, see pdf. I'm currently using ATF in my cruiser but have used and liked Honda 8 and Harley E in the past.
In the chart the blue numbers are the viscosity when oil is heated up. Once oil is heated up many of them settle into viscosity in the middle of the range.
Mobile 1 Syn ATF has 40C viscosity of 36.3 and at a 100C 7.4, you can find the data on ATF mfg's website under "Product Data Sheet".
File Type: pdf Shock_Fluids_Comparison_Suspension_Oils_Chart.pdf (15.2 KB, 101 views)
1998 Shadow 750 ACE
Bunch of others
MinnesotaGreg is offline
post #9 of 31 (permalink) Old 11-20-2012, 03:43 PM
ATF is approx 7.5wt.
93gc40 is offline
post #10 of 31 (permalink) Old 11-20-2012, 04:48 PM
04LowShadow's Avatar
Interesting.
Sent from my DROID RAZR using Motorcycle.com Free App
04 Aero 750
Cobra HP Pro Exhaust,Wrapped
De-snorkeled,K&N AF, Dyno Jet JK
Blue Collar Bobbers 31" Drag bars and Risers, Avon Grips,Baron Tach
Goodrich Braided SS/Black Teflon front brake line, EBC HH Front brakes/EBC Rear shoes
ScootMods 4" Control Extensions
ScootWorks Front/Rear 1.5 Lowering Kit
Shaved Stock Seat (Self made)
Flush Mount Tag (Self made)
04LowShadow is offline
