What size carb jets do I need? - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-21-2012, 06:50 PM   #11 (permalink)
Originally Posted by C.W. View Post
Mine's a 1994 but close. And researching just made it even worse, now I'm reading about people using different sizes for each carb. Everyone uses a different size jet, different needle notch, and different A/F screw turns. My mind has been nuked.
edwardl is offline   Reply With Quote
Old 11-21-2012, 07:55 PM   #12 (permalink)
justinmahn's Avatar
Ok you need to break this up into steps. Put what you have back together, describe how it idles, accelerates, and decelerates. Also post a pic of a spark plug after a 5 minute ride.
All this advice requires you to know what your starting point is.
Sent from my MB886 using Motorcycle.com Free App
Old 11-21-2012, 08:20 PM   #13 (permalink)
1994 Shadow 600 VLX dual carb.
Stock exhaust with mufflers cut off.
Stock Airbox removed, pancake filters added to carbs.
Cobrajet Stage 1 jet kit already installed.
Bike idles fine.
Bogs on acceleration then kicks in and goes.
Pops on deceleration.
Can't take the plugs out until I get a new spark plug socket, mine doesnt fit.
Old 11-21-2012, 08:58 PM   #14 (permalink)
justinmahn's Avatar
There's your next step. Get the spark plug socket. Get the one from honda, because it's uniquely shaped.
Until then you can do the pilot idle adjustment, according to C.W.'s link. From your description, I would guess your pilot is set lean. There is no need to replace the jet, unless you reach the end of your adjustment range.
Old 11-21-2012, 09:24 PM   #15 (permalink)
C.W.'s Avatar
Sorry. Didn't mean to fry your brain. Just trying to help.
If this is your bike, try the jet calculator.
Honda VT600C VT600CD 1988-1994 Carb Jet Kit Calculator
Good luck!
2008 Aero 750
"Hear the pipes" video
C.W. is offline   Reply With Quote
Old 12-06-2012, 02:25 PM   #16 (permalink)
Ended up ordering 42 pilot jets and 125,128, and 130 mains. Put in the 42s and the 128s and got lucky, bike runs fine now. Thanks guys.
Old 12-06-2012, 04:09 PM   #17 (permalink)
Have you been able to check the plugs? If so, what color or indications were they giving off?
Damian
Image is pointless if you don't do the riding part; get out on the road and out of the bar!
Damian
'00 Sabre
damian.garcia83 is offline   Reply With Quote
Old 12-06-2012, 07:02 PM   #18 (permalink)
No I haven't, I have to order a spark plug socket.
