#11 (permalink) | |
#12 (permalink) |
Rodger on the no kickstand switch.
The supposition on the last ditch effort on the seat bolt (failing all other attempts) was that after the bolt head was removed, the seat would come off. Then there will be no tension on the threads, and enough threads left above the fender to grab with vice grips. Again that's a last ditch effort. |
#13 (permalink) | |
But I'm sure a vise grip will do the trick. You can see the nuts on the stubs here: Just to be sure, this is what I'm talking about:
![]() Honda VT750C 83 Full Restoration Log Photo compilation (5 minutes video) Riding my Honda VT750 to the marina (14 minutes video) Last edited by luisr320; 11-22-2012 at 09:29 PM. |
#18 (permalink) | |
Does this bike have a clutch or nuetral switch. Does bike idle? and accept throttle when in nuetral. OR does it ONLY die when in gear?
#19 (permalink) | |
Thank you. Regarding the clutch switch, I see where you're going with that. This bike has a clutch switch on the clutch lever (sorry for stating the obvious). It is a normally open circuit. When you press the clutch, the switch will open. If the bike is out of neutral, you can't start it unless you press the clutch lever. So if the switch was malfunctioning, you could only start the bike in neutral. And as soon as you engaged 1st gear, the engine would dye. If this happens, then the problem would be the switch. Good catch, 93gc40.
![]() Honda VT750C 83 Full Restoration Log Photo compilation (5 minutes video) Riding my Honda VT750 to the marina (14 minutes video) Last edited by luisr320; 11-24-2012 at 11:52 AM. |
#20 (permalink) | |
To the TS - sure the carbs need cleaning, and pay special attention to stucked enrichener(choke) lines. Good luck and congrats for the bike - maybe one of the finests in the history of motorcycles! |
