#21 (permalink) |
sorry I'm a noob what bolt inserts under the fender?? and yes the bike chooses when it wants to idle or not but it has started to be exact i would charge the battery in my house go out insert it and get it started 3 times max by luck but when i would try to pull of and give it gas and release the clutch it would shut off. and sometime it won't even go back to neutral sometimes. and yes the bike accepts throttle in neutral.
#22 (permalink) | |
#23 (permalink) | |
#24 (permalink) |
Did you managed to remove the nut that hold s the seat? That nut is screwed on a stub that is welded to the rear fender. If on your efforts to remove that stuck nut, you end up ruining that stub, or even if the only way that nut comes out is by cutting it with a dremmel cut disk, you could always cut the whole stub from the fender, drill a new hole where the stub used to be and later on, when you want to put the seat back on, you just insert a bolt with approximately the same dimensions from underneath the fender.
But try to remove that nut first and we'll see what you should do next. |
#25 (permalink) |
If you don't know what your doing it might be cheaper to let a mechanic do the work, it's $500 well spent if your going to get frustrated and not enjoy the work!! If your up for it first thing is get a beer and enjoy the work it can be real fun and challenging!! next trouble shoot the jobs and do one thing at a time. Sounds like a few problems. 1) get a good manual. 2-stalling-change the gas filter, new plugs, new air filter, and rebuild carbs. 2) not starting- test battery,check power to starter, follow the test procedures in your manual to solve these problems!! To remove the bolt thats stuck, like the man said heat it and remove it or grind it off. And don't use vice grips unless you absolutely have to, get good 6 point sockets, they won't strip the bolt head to begin with.
#26 (permalink) | |
They are attached to the carburetter by a black plastic nut. Here, check out these photos from my disassembly: With choke attached (black rubber boot) Without choke attached See the yellow cylinder on the foreground? That's the choke. Be careful not to loose the spring if you take it off from the cable. |
#27 (permalink) |
ok so i should remove it carefully, thanks i ill be attempting to remove the carb. on wed. my day off so any advice on what to take out first and what to look out for? also I'm buying some carb cleaner liquid and I'm going to full up a bucket with it and place the carb in it after is that how its done.?
#28 (permalink) | |
#29 (permalink) | |
http://www.linhadafrente.net/Honda75..._1983-1985.pdf If you are on a budget, don't print it. Just use a laptop next to your bike and follow the instructions. After opening the top of the carburettor be careful with the sliding diaphragms. They are about 100$ each. Also be careful with the jets. They are made of brass and brake easily if you force them out with a screwdriver. DO NOT SEPARATE THE CARBURETTORS UNLESS IT IS NECESSARY. Be careful with the needles, they are very thin and easily damaged. So after openeing both end of the carburettors, remove the sliding diaphragms and the rubber gasket from the bowl (you should have a new ones to replace in the end). If you have carb cleaner in a spray can, spray the hell out of it. It it is in a container, drop the whole carbs in it overnight, but remove the diaphragm first. They are made from rubber and my not like to be in there for long. If you can, take out the main jets, and see if they are clean. I have lots of photos that I took from the work I did on mine, so if you want I can post them here for reference. Also, take some photos of your work and post it here for our enjoyment. |
#30 (permalink) | |
Air Cleaner Honda VT750C Shadow 750 1983 OEM Parts - Cheap Cycle Parts As for the fuel filter, the OEM is expensive. I found a couple that look just like the original one and cost about 6$, but I'm not sure if they are exactly the same. |
