large fuel leak - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 11 (permalink) Old 11-22-2012, 11:00 AM Thread Starter
flybuy's Avatar
large fuel leak
I recently got my 98 Aero 1100 back from the shop. New tires, carb sync, oil change. I know the bike has more time on it than miles, but what are the odds that the old girls carbs are synced and then the fuel pump starts leaking. I look up under the carriage where the fuel appears to be leaking.
Description of leak, or what appears to be leaking. It looks like the little brass barrel has permatex pushed out of it. I will score some pics if needed.
Any information would be helpful on this. Especially DIY
flybuy is offline
post #2 of 11 (permalink) Old 11-22-2012, 01:08 PM
John Hopkins's Avatar
Photo's will help, otherwise we can only guess..Try a distance shot with an arrow or screwdriver pointing to the spot that is leaking and a couple of close ups from different angles.
John.
John Hopkins is offline
post #3 of 11 (permalink) Old 11-22-2012, 01:16 PM
Only you can find the leak, without pics. Most leaks are from bad hoses, but I have seen pumps fail and leak. How long after getting it back from the shop did this happen? What else did the shop do to the fuel system? And how much did you pay for $70(parts/supplies) and 2 hours worth of labor? First doing a sync is a waste of time and $$ unless you first adjust and service the fuel, ignition and charging systems. Sync is not really a service item, it is more a fine tunning and diagnostic item. My bike goes out of sync I know I have issues, or potential issues, in the fuel system, ignition or valve train.
93gc40 is offline
post #4 of 11 (permalink) Old 11-22-2012, 02:52 PM Thread Starter
flybuy's Avatar
not long. it looks like it is leaking from above the pump. both the inlet and outlets to the pump on the exhaust side are dry, the filter (i think its a filter right below it as you look up) are dry. It looks like its leaking from above it.
Is there something above it. Next step is to start taking $#!+ apart. Would like not to have to tear this thing all the way down.
flybuy is offline
post #5 of 11 (permalink) Old 11-22-2012, 04:19 PM
Although the vt1100s are very similar there are quite a lot of differences, but without photo's none of us can do more than guess..you should be looking at the petcock, is the filter full of dirt, has one of the hose clips eaten into the hose, is a hose cracked or split..The hose coming down from the petcock has a right angle bend in it where it clips on to the petcock, mine had perished on that bend..get a piece of absorbant paper and wrap it around the hose at the petcock, move it down until it shows wet..that could be the best place to start, It's not much good taking stuff off because you will hide the problem if it is a pinhole..
John.
post #6 of 11 (permalink) Old 11-22-2012, 05:02 PM Thread Starter
flybuy's Avatar
93gc40
Not long. Only paid 40$ for the carb sync.
The tech at the shop mentioned the tank needed to come off to service.
Are there other lines on the tank that will leak from over top of the fuel pump.
John H
I took the towel in my had around the petcock all the way down as far as my hands would allow. Cannot get into the leaking area. That is why I was asking about the other lines.
I have tried to read about the carb sync but not really sure from what I read whether the shop would have even been the area around the swing arm.
I will be adding some pics very soon
flybuy is offline
post #7 of 11 (permalink) Old 11-22-2012, 06:06 PM Thread Starter
flybuy's Avatar
ok here is an attempt at downloading a pic.
To the right of the pencil are the 2 fuel lines to and from the pump.
The pencil is pointed at the center part of the pump that is slighly wet.
The majority of the fuel runs down behind and on top of the swingarm
flybuy is offline
post #8 of 11 (permalink) Old 11-22-2012, 07:13 PM
That filter needs changing.
John.
post #9 of 11 (permalink) Old 11-22-2012, 07:25 PM Thread Starter
flybuy's Avatar
so you think a filter will fix a leak?
OEM or Aftermarket
flybuy is offline
post #10 of 11 (permalink) Old 11-22-2012, 08:13 PM
Scrapdog2grand's Avatar
This may be a little tough to clean up, but what we do for hard to find leaks is use leak check, OR foot powder in a spray aresol can. spray the area with the foot powder, it will be all nice and white, when it starts to leak it will become dark and very noticable. spray the entire area, you may also need a mirror to look up in there.
1999 VLX
1998 SA750
1991 NSX
Scrapdog2grand is offline
