Another Oil Change Question - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-23-2012, 06:19 PM   #11 (permalink)
Like gat said, total BS. I change mine in the fall and then park the bike till spring. Never an issue.
2006 Honda Sabre
Old 11-24-2012, 10:30 AM   #12 (permalink)
I haven't had a heart attack or cancer. Does that mean I should keep smoking?
BS yes, but not total BS.. Remember those recomendation are meant to cover everyone. The guy living in the desert of Arizona, the guy who gets 4 huricanes a year the guy that get 30 feet of snow for 9 months a year, the guy that has haboobs, the guy that rides on only the city streets, the guy that rides mostlly freeway, thae guy the puts and the guy that blasts down the road, you get it. Every bike has different needs, Not like they can write service recomendations to fit every possible scenerio or consition. So they generalize and give RECOMENDATIONS for the required services at APPROXIMATE intervals. The services are always required, the extent and periodicy of those services will and do vary
Old 11-24-2012, 11:16 AM   #13 (permalink)
LANCESSABRE's Avatar
hmmm so which one of us is going to run about a hundred miles or so in the spring then send out a sample to get analized? right now i'm leaning to way of bs, there is a burn out procedure to get water out of submurged pwc's so i'm with the moisture will burn off..
LANCESSABRE is offline   Reply With Quote
Old 11-24-2012, 01:56 PM   #14 (permalink)
morepower's Avatar
Send a message via Yahoo to morepower
OK. I can see the wisdom of changing oil BEFORE going into storage. Over the season the oil picks up contaminates from moisture and combustion that could cause corrosion in the crankcase. But where I call BS is the recommendation to change it again after storage. The crankcase is essentially sealed except for a small vent, so new oil in the crankcase is not that much different than new oil still in the bottle. It's not doing anything except sit there. I cant help but wonder if Honda is just hoping that owners that will follow the manual that closely will also be using Honda oil. More revenue. If the new oil is going to be drained out unused, why not just store the bike without oil and hang a tag on the bike saying "add oil"?
Non Impediti Ratione Cogitationis
HardKromes, K&N, Bean Mod, 4* Timing Mod. Custom black metalflake
morepower is offline   Reply With Quote
Old 11-24-2012, 03:33 PM   #15 (permalink)
I'm with gat too!! Once you fire the bike up any moisture will be gone, that's the white smoke you sometimes see on start-up. A more benificial thing to do would be to presurise the oil system befor firing it up, imo.
vonh is offline   Reply With Quote
