1993 VT 1100 engine performance issues - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-24-2012, 07:05 PM   #1 (permalink)
Default 1993 VT 1100 engine performance issues
Hi to all forum!!
i am long long away from the States(Europe) but i am driving a 1993 California model shadow.The one with the canister but i have removed canister,tubes and valves.So here is my problem.Bike starts ok,idle is ok but during driving when i open the throttle instantly the engine stalls.When the throttle opening is progressive revs go up normal. I have cleaned and balanced carbs,checked the plugs and swap fuel pump with another one but with no results.Have you any idea?
viper1 is offline   Reply With Quote
Old 11-24-2012, 07:29 PM   #2 (permalink)
luisr320's Avatar
Hello friend. I'm inEurope too, in Portugal, to be more precise. Where are you?
Have you tried to run the engine without the air filter?
Old 11-24-2012, 08:40 PM   #3 (permalink)
John Hopkins's Avatar
I don't think you can just remove the evap control system without changing the carbs or at least linking the hoses from the purge control valve..I would bet that is where your problem lies, but I have never removed one on my bikes and I haven't examined the system enough to help you..
John.
Old 11-24-2012, 09:14 PM   #4 (permalink)
My location is in Athens Greece and concerning the filter i have not driven with out it installed but i will try
Thanks for the reply
Old 11-24-2012, 09:18 PM   #5 (permalink)
John.
Hi John
i had the same problem before deactivating the evap system.I have connect all the vacuum lines so there are no leaks.Is there any chance the fuel pump does not deliver the correct amount of fuel on sudden demands?
Old 11-24-2012, 09:36 PM   #6 (permalink)
Scrapdog2grand's Avatar
I would say no on the fuel pump.
did you check your vacuum diaphrams for holes while you had the carbs apart, is there a vent with a sub air filter for the vacuum diaphams?
1999 VLX
1998 SA750
2003 SA750
Old 11-24-2012, 09:48 PM   #7 (permalink)
Checked all diaphragms and were ok.I am not aware of any sub air filter.If there is any where is located?Inside the carbs?
Old 11-24-2012, 10:11 PM   #8 (permalink)
PM Sent
finjoey is offline   Reply With Quote
Old 11-27-2012, 03:03 PM   #9 (permalink)
I'm not sure about the evap. control system and have concerns there too. But it sounds like your flooding your carbs on quick acceleration, try leaning your mixture out a bit or re-jet for a leaner mixture
vonh is offline   Reply With Quote
Old 11-28-2012, 04:39 AM   #10 (permalink)
i am worring about the accelerator system of the carbs but i will try to lean it from the pilot screw.It is the only thing i didn't touch when i disassempled the carbs for cleaning
