#11 (permalink) | |
Check the fuse by setting the meter to about 20v dc and with the ignition switch on, put the negative lead of your meter to the negative pole of your battery then touch each side of the fuse and expect 12v dc..then check all the other fuses..If you have 0v on both sides of ONLY the headlight fuse the fault is a poor connection on the back of the fuse box.. The first step of electrical fault finding is to check for dc volts across the battery..then check that the leads are tight on the battery then check that you have the same voltage from the positive pole of the battery to ground (frame) because the negative pole of the battery is tied to the frame.. John.
#13 (permalink) | |
Man, I took another look at that fuse box this morning. I don't know how I'm going to get inside there.
'99 Shadow VT1100C Spirit - daily driver '99 Rebel CMX250C2 - Sold! '83 Shadow 750 - goodbye and good luck '72 CL350 - You never forget your first |
#14 (permalink) | |
don't make it hard for yourself by trying shortcuts.. John.
#15 (permalink) |
It was dark. I was cold. I was getting aggravated. At least I knew when it was time to put.the voltmeter.down. and go get a drink. We'll try again tonight, thx.
#16 (permalink) |
There is contact in the start button to disable the headlight as you are starting it so the headlight doesn't drain the battery. Since you have running lights and a headlight the contacts could have burned through. If the Aux lights were wired in the same circuit as the headlight it is too much current for the start switch. Aux lights shouls alwasy be powered directly from the battery through a relay that is triggered by the headlight.
#17 (permalink) |
As John said. you have to use a good ground when checking for voltage at the fuse, if you have voltage then you go to the Start switch, if good there you go to the dimmer hi/lo switch and anything else that may be in between the 2 of the switches, a connector perhaps.
#18 (permalink) | |
Sorry but that is wrong..If you have voltage at the fuse it has already come from the battery to the ignition switch and on to the fuse.. All I ask is that if you do the things I say and then tell me the results I will tell you what to do next..I can't test it for you myself because my arms aren't long enough to reach.. To the person who said the ignition switch could be faulty..that is true but the bike is only 13 years old if I understand correctly and the contacts usually last for at least 25 years..However if there is no voltage at the fuse that will be the next step and the contacts can be repaired.. Because of the strange method of testing the fuses we will just have to wait and see.. John.
#19 (permalink) | |
#20 (permalink) | |
John.
Beauty is only skin deep but ugly goes right to the bone. Last edited by John Hopkins; 12-01-2012 at 07:22 AM. |
