#11 (permalink) | |
#12 (permalink) |
Great tip, and I will do that, but I have a reason to suspect the "thermistor", as it (bike) sat in water for a short while... The fan worked afterwards, but maybe corrosion occurred over time(about 2 weeks later) - or is it not a possibility at all, as it seems well protected by its sleeve, and not much is exposed to the outside water, and maybe I shouldn't bother getting to its "innards"?
#13 (permalink) |
Ok amigos, assuming the test of the fan works with a blown fuse(again, after yesterday's test it burnt out and I did not have the spare this time), with ignition "on" I unplugged that spade connector, and touching it to the frame - no fan movement. the connector looked nice and clean on both ends - switch in the radiator (thermister) end, and wire. So, I tried spinning the fan by hand, as I remember it would freely turn by hand - no way, it is not moving. Now, fan & it's motor is my suspect - correct?
#14 (permalink) | |
John.
#16 (permalink) |
Just wheel the bike outside over a drain and undo the bottom radiator bolts the undo the bottom hose
the rest is even easier. John.
#18 (permalink) |
new fan is definitely in the cards. I will try to revive this one, but chances are it's seen its better days... I really want to thank all of you for the help - without it, even these seemingly simple tasks would be impossible for someone like me, without much of technical experience and knowledge. Equipped with your friendly support, I see how working on the bike can be enjoyable, gratifying experience. Especially when there is a warm place to do it in, and tools are at hand. (not my present situation, but I do see it
