overheat light on - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 18 (permalink) Old 11-30-2012, 01:26 AM Thread Starter
overheat light on
the red light came on after about an hour of riding. As i got off the highway, sat in a mild traffic, and the light turned on. I got off the road, turned the engine off. Few minutes later, start, and off I went, without any problems. After a while, I rode back, also problem free. No weird noises. The fan did not seem to go on. A week ago I rode in a heavy traffic for an hour, and definitely heard the fan coming on. As I rode fast, without the traffic on the way back, and in somewhat cold temps of close to 33F, I think I could have been getting away with "air cooling", but I'm wondering if there is something wrong with fan or thermostat - any way to check it? It was a bit too dark to really see what's the level in the coolant reservoir, will take a look tomorrow, as the daylight would be helpfull...
Oh, BTW, it is ACE 750...
harpomatic is offline
post #2 of 18 (permalink) Old 11-30-2012, 06:21 AM
John Hopkins's Avatar
Look at the engine side of the bottom of the radiator, there is a single wire connected to something that looks like a large bolt, it has a spade connector so you can just pull it off..
With the ignition switched on touch that spade connector to any bolt that connects to the frame (ground) if the fan is ok it will run..
A modification you might want to do for when you are stuck in traffic and the engine is getting hot:-
Fit a handlebar switch and run one wire to the spade connector wire (you can get a simple in line adaptor) and the other wire to ground or frame..Now with the switch off the fan will start as it normally does but you can bypass the thermal switch and switch the fan on anytime you want to.
John.
John Hopkins is offline
post #3 of 18 (permalink) Old 11-30-2012, 11:48 AM Thread Starter
thank you, John! I will do this check, wonder where are the fuses located, just in case...
post #4 of 18 (permalink) Old 11-30-2012, 12:02 PM
Phantomjr's Avatar
Assuming all 750s are similar, its behind right side cover.
Phantomjr is offline
post #5 of 18 (permalink) Old 11-30-2012, 12:07 PM Thread Starter
thank you, will report on my progress!
post #6 of 18 (permalink) Old 11-30-2012, 01:16 PM
SkullCrusher's Avatar
Also check coolant levels.
SkullCrusher is offline
post #7 of 18 (permalink) Old 11-30-2012, 04:04 PM Thread Starter
ok friends, luckily I found the immediate problem right away - the fuse(fan) was blown, indeed. Now, what caused it - I hope just old age, it seemed a bit oxidized... Coolant level is just right, could not really find those switches on the bottom of my radiator, though...
post #8 of 18 (permalink) Old 11-30-2012, 05:27 PM Thread Starter
ok, aparently, the fan is not kicking in - i started the bike, let it idle for about 20 minutes - the light came on, but the fan did not kick in. Will check the fuse tomorrow, as it got too dark to see now...
Also, John - are you talking about the very bottom left on the radiator, where I see some black wire with a black rubber sleeve going into what looks like, rather a large "nut", or a bit above, midway - there are also wires with a white rectangular "connecting", or may be it is only a fastener kind of thing. Not being shure what to pull, I thought I'd rather ask first. Both are on the left side(from sitting on the bike point of view), 98 Ace750.
post #9 of 18 (permalink) Old 11-30-2012, 08:30 PM
To test the fan you do not need the engine running just the ignition switched on...
That rather large nut is a thermistor it has a single wire connected to it with a push on spade shaped connector which just pulls off..if you touch that to ground the fan should run..
The thermistor changes it's resistance and opens a path to ground when it gets hot..having a lot of sludge in the bottom of the radiator can insulate the thermistor from the hot water and stop it from working..but the test I described bypasses the thermistor.
John.
post #10 of 18 (permalink) Old 11-30-2012, 09:27 PM Thread Starter
Got it John , thank you, will do tomorrow. While i am there - maybe I should pull the thermostat as well, to check it's condition, can it just be unscrewed (the "nut")? Do I drain the radiator for that? I did some search on these questions, but so far did not find much info yet...
Edit: Just checked clymer's - they call it "fan switch", I'm sure John means to unplug there, but if anyone has a tip on the possible cleaning procedure of that unit - would be great to be equipped with some wisdom from fellas here...
