adding a switch to radiator fan - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-03-2012, 10:06 AM   #1 (permalink)
Send a message via Yahoo to stubb
Default adding a switch to radiator fan
I know i have seen this somewhere but i cannot find it for the life of me. I want to add a switch to the radiator fan for summer riding. It gets hotter than hell here during the summer and i want to be able to turn the fan on via a switch.
The way i seen was you can add a switch to one of the wires turn the fan off and on as you please while still having the ability of using the temp switch to have the fan turn on on its own like normal.
any one run this setup? if you can point me in the right direction i would appreciate it.
thanks
stubb is offline   Reply With Quote
Old 12-03-2012, 10:21 AM   #2 (permalink)
Should be no reason to do this if the cool system is working properly. Using a bypass switch can hide a problem and cause more harm.
jpr1968 is offline   Reply With Quote
Old 12-03-2012, 10:47 AM   #3 (permalink)
Scaredofmyownshadow's Avatar
There was a thread called " overheat light on" just the other day. The first reply was by John Hopkins. He explained how its done.
Scaredofmyownshadow is offline   Reply With Quote
Old 12-03-2012, 11:02 AM   #4 (permalink)
Aced It's Avatar
thanks
^^^ That explains it. The electric fan is designed to come on as the temperature of the coolant rises to a certain degree, regardless of the outside/ambient temperature. If you're having a problem with the engine not cooling properly, a switch to keep the fan "on" will only mask the real problem. Other than that, a properly running fan will do it's intended job.
^^^ Hopefully that gets your answer.
Keep the rubber side down ... unless of course you have a rubber head!
My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It
ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf
Aced It is offline   Reply With Quote
Old 12-03-2012, 12:49 PM   #5 (permalink)
Additionally electric motors tend to draw quite a bit of current. If you run the fan continuously the battery may not get enough charge.
dgraves49 is offline   Reply With Quote
Old 12-03-2012, 01:38 PM   #6 (permalink)
I wouldn't do it either your just adding another possible problem to your electrical system.
vonh is offline   Reply With Quote
Old 12-03-2012, 02:27 PM   #7 (permalink)
ok ill just leave it as is thanks for the input.
Old 12-03-2012, 05:17 PM   #8 (permalink)
Super Moderator
old dad's Avatar
you have chosen wisely.
2006 vlx
Old 12-03-2012, 10:21 PM   #9 (permalink)
Thunder Johnson's Avatar
Default Maybe a Chin Spoiler?
From a post here, Air Dam VT1100C 87-96
Thunder Johnson is offline   Reply With Quote
