This there a "how to" - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-03-2012, 04:00 PM   #11 (permalink)
gat803's Avatar
Originally Posted by luisr320 View Post
Since everybody (almost) have a battery charger, I think this is a cheepo way of maintaining the battery alive during the winter.
I paid, like $18 for my Schumacher Battery Tender. A programable 7 day timer is what $12 - $15? Doesn't seem worth the effort.
Hey look, a covered bridge...
Old 12-03-2012, 05:15 PM   #12 (permalink)
Super Moderator
old dad's Avatar
Dude,,you don't have to take the seat off of the vlx to access the battery,,get at the poss terminal from the right side cover,,access the neg. terminal from the left side. Easy
2006 vlx
Old 12-03-2012, 05:26 PM   #13 (permalink)
C.W.'s Avatar
I mounted the ring connectors at the opposite end of the battery cables (not the battery end, but the other) and routed the adapter cable so the male/female connector is just under the right side cover with the loop that holds the protective plug hanging out the bottom of the side cover. I can just grab the loop and pull it out and make the connection. Then, when I want to ride, I unplug charger, disconnect, connect the protective plug, and push it back up in the cover with the loop hanging out again. Very simple.
2008 Aero 750
"Hear the pipes" video
C.W. is offline   Reply With Quote
Old 12-03-2012, 08:26 PM   #14 (permalink)
07SilverShadow's Avatar
Ill have to tackle this, this weekend... doesnt look too hard
.. im gonna try to do it without taking the seat off.
2007 Honda VLX 600
07SilverShadow is offline   Reply With Quote
Old 12-03-2012, 08:35 PM   #15 (permalink)
The seat is the easiest thing to take off. It takes about a min and a half on a slow day. And as said before its just to hook the cable up the first time, then the connector stays there and you plug in the tender when you want. I have mine under the seat so you can't see it.
2001 spirit 1100 , vance and hines long shots, , a few other small mods. Now also with a mustang seat
dorfman17 is online now   Reply With Quote
Old 12-03-2012, 09:04 PM   #16 (permalink)
DRVMN's Avatar
I wired the ring terminals directly to the battery so now all I have to do is hook the tender up - takes about 20 seconds. When not in use, the wire harness hides behind the key switch. The wire harness also works for my mini compressor (Slime brand) that I bought.
Here are some pictures:
2009 Honda Shadow Spirit 750
-Mustang Seat & Backrest
-Memphis Shades Windshield & Lowers
-Saddlemen Highwayman Saddlebags
-National Cycle Paladin Highway Bars
-Show Chrome Accessories Radiator Cover
-Kuryakyn ISO Pegs (Driver & Passenger)
-Kuryakyn ISO Grips
-Honda Luggage Rack and Sissybar
-Honda Saddlebag Supports
DRVMN is offline   Reply With Quote
Old 12-03-2012, 11:12 PM   #17 (permalink)
Super Moderator
old dad's Avatar
ya don't have to take off the vlx seat to do this...
2006 vlx
Old 12-04-2012, 01:57 AM   #18 (permalink)
Same as (aced it). Mines is a.7 amp and I just leave it plugged in all the time it's supposed to be automatic
vonh is offline   Reply With Quote
Old 12-04-2012, 07:11 AM   #19 (permalink)
vzshadow's Avatar
It is extremely easy to take the seat of a VLX.
I seem to remember explicit instructions to take always disconnect one of the battery terminals first. I think it's the negative, but I'm not sure. You think I'd remember as I recently removed the battery out of my wife's PCX scooter and hooked up a tender to my Bonneville.
Check the manual. I don't know what the consequences are if you do it in the wrong order.
vzshadow is offline   Reply With Quote
Old 12-04-2012, 07:45 AM   #20 (permalink)
Aced It's Avatar
Originally Posted by vzshadow View Post
... I don't know what the consequences are if you do it in the wrong order.
Fire and brimstone coming down from the skies! Rivers and seas boiling! Forty years of darkness! Earthquakes, volcanoes ... The dead rising from the grave! Human sacrifice, dogs and cats living together... mass hysteria!
Keep the rubber side down ... unless of course you have a rubber head!
My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It
ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf
Aced It is offline   Reply With Quote
