1984 shadow 700 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-03-2012, 10:41 PM   #1 (permalink)
Default 1984 shadow 700
ok guys so i bought this bike with bad fuel pump so i got a aftermarket but i got a 3psi and its over flooding my carbs whats the correct fuel pressure ? any suggestions are appreciated
m-power1989 is offline   Reply With Quote
Old 12-04-2012, 08:08 PM   #2 (permalink)
anyone ?i have searched and cant seem to find the specs on it
Old 12-05-2012, 10:56 AM   #3 (permalink)
kyxon's Avatar
I found this thread that suggests 3 psi up to maybe 5 psi.
Fuel Pump Replacement options for 80's Shadow
kyxon is offline   Reply With Quote
Old 12-05-2012, 11:05 PM   #4 (permalink)
ok guys so the fuel pump i got is a 2-4 psi
but is causing my carbs to over flow and lots of gas come out of a hose that goes underneath my bike
would that be the pump ? or something with the carbs ?
Old 12-05-2012, 11:11 PM   #5 (permalink)
lots of gas come out off this hose (not my actual carbs)
Old 12-06-2012, 08:36 AM   #6 (permalink)
Sounds like one of two things, either you got a defective pump that puts out way too much pressure (not too likely) or your carb float valves are stuck open. You may be able to unstick the valve or valves by tapping on the side of the carb, or else it is time to pull the carbs. A carb repair kit will include the valve plungers that have a rubber tip. this part may be shot after all these years. Good idea to check your oil to see if it is gas contaminated. Drain it if it appears too full.
01 Sabre Dave
08 V-Star 1300T Sarah
verdeva is offline   Reply With Quote
Old 12-07-2012, 09:45 PM   #7 (permalink)
my float seem ok
Old 12-07-2012, 09:45 PM   #8 (permalink)
what else could cause this
Old 12-07-2012, 10:04 PM   #9 (permalink)
roscoenr's Avatar
Are the jets ok
Sent from my PG86100 using Motorcycle.com App
84 VT500
86 VT700
roscoenr is online now   Reply With Quote
Old 12-08-2012, 07:24 PM   #10 (permalink)
gmck's Avatar
Float might be fine but the needle valve is leaking. Only way I know of for fuel leaking from the overflow is the inlet valve to leak or too much fuel pressure causing the valve to leak. Check fuel pressure.
