Leak Proof Seals vs. O.E.M. fork seals - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-04-2012, 01:43 PM   #1 (permalink)
SuperiorKolours's Avatar
Default Leak Proof Seals vs. O.E.M. fork seals
Have you tried them?
Notice any difference?
Heard anything?
The claim:Leak Proof fork seals positively stop leaking fork oil and reduce stiction up to 80%, compared to regular fork seals Pro-Moly seals reduce stiction 20% more than standard Leak Proof seals Teflon coating significantly reduces seal drag in todays sophisticated front forks
SuperiorKolours is offline   Reply With Quote
Old 12-04-2012, 02:30 PM   #2 (permalink)
Super Moderator
Phil's Avatar
Can't speak for these seals, but I would think the stock OEM seals should be more than sufficient.......
Phil
1973 Yamaha RD-350
Sterling Heights, Michigan
Phil is offline   Reply With Quote
Old 12-04-2012, 02:36 PM   #3 (permalink)
Phil
I would tend to agree, but these come with a lifetime warranty!
Old 12-04-2012, 02:42 PM   #4 (permalink)
Super Moderator
Phil's Avatar
Maybe you can find them on a site like Amazon.com and see if there are any reviews from people who have used them?
Phil
1973 Yamaha RD-350
Old 12-04-2012, 03:00 PM   #5 (permalink)
FYI
Ain't no such thing s a a "Leak Proof" seal...
Any seal can and will leak if left in service long enuff.
Black Beast = '71 CB750
Lazarus = '86 VT1100C rescued from a salvage yard.
GrumpyOldMan is offline   Reply With Quote
Old 12-04-2012, 03:37 PM   #6 (permalink)
ZackDaniels's Avatar
Most of what causes fork oil leakage to any excessive amount isn't the seal but rather the bushings which cause flex in the tubes and oil to blow by the seal. This is why it's almost an automatic to replace the bushings when you replace the seals, because if it's not already the barring then it's not far behind.
I don't think I'd want a seal that worked so well as to mask a bushing problem.
ZackDaniels is offline   Reply With Quote
Old 12-04-2012, 03:42 PM   #7 (permalink)
Originally Posted by ZackDaniels View Post
Most of what causes fork oil leakage to any excessive amount isn't the seal but rather the barrings which cause flex in the tubes and oil to blow by the seal. This is why it's almost an automatic to replace the barrings when you replace the seals, because if it's not already the barring then it's not far behind.
I don't think I'd want a seal that worked so well as to mask a barring problem.
Which bearings are you referring to? Steering stem bearings?
Old 12-04-2012, 03:56 PM   #8 (permalink)
Mentally on a different page than my fingers were. I meant to say bushings all those times - edited my post to reflect that.
Must be a Monday!
Old 12-04-2012, 05:20 PM   #9 (permalink)
Sgoatley's Avatar
Heard anything?
What the heck is stiction????
Steve G.
North Carolina
2006 Vlx Deluxe
When I grow up......ahh hell I ain't plannin to do that!
Sgoatley is offline   Reply With Quote
Old 12-04-2012, 05:51 PM   #10 (permalink)
Must be a Monday!
Still dont know what bushing you are referring to...
