#11 (permalink) | |
after double checking the diagram, I to would suspect the ICM. The black wire at the fuel cut Relay should be hot, and the yellow and blue will also be hot till the ICM grounds that rear coil, at that time you should get power to the other wire at the fuel cut relay black with blue. when you said you have continuity did you check the actual ohm's? or just do a continuity test with the beep? I would check for any resistence readings that may be more than 1 or 2 ohm's if checking for continuity to ground if you didnt all ready. do you have a service munual? if not you can download a factory manual at the link in my sig. if I dont get back to you please let me know the outcome/fix.
#12 (permalink) |
Hey, Thank you for all your help, I will go back over the connections, yes, I did just use the beeper. But I am gonna go ahead and get the icm (used) and keep my fingers crossed. I'll let you know as I will also be an expert before this is fixed.
Jim |
