#11 (permalink) | |
#12 (permalink) |
![]() Keep the rubber side down ... unless of course you have a rubber head! My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf |
#13 (permalink) |
You've got the spoke rims on your 08 Aero which need tubes. I don't know if running tubes in a radial tires is an issue or not, but I think that is why most tires for this bike are bias ply. You can run a 170/80 on the rear with no problem. You could go with a different brand tire. OEMs are to keep costs down and are not the best tire IMHO, unless for some reason you are dead set on getting the Bridgestones.
#15 (permalink) | |
Sent from my SCH-I535 using Motorcycle.com Free App
#16 (permalink) |
This is driving me nuts.
honda shadow aero 750 2008 Can i put a 120/90-17 64h bridgestone g701 on the front and a 160/80-15 74s bridgestone g702 on the back? every where i look no one has two of the exact same rated tires in stock. At least not at decent prices. |
#17 (permalink) | |
I don't know what you would consider as a decent price through a giant, and those aren't bad - AND - you're getting free shipping!
![]() Keep the rubber side down ... unless of course you have a rubber head! My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf Last edited by Aced It; 12-07-2012 at 03:18 PM. |
#18 (permalink) | |
#19 (permalink) | |
Also, don't forget tubes! I can understand your thoughts about sending back, but you shouldn't need to. Sent from my SCH-I535 using Motorcycle.com Free App
#20 (permalink) | |
Well i order the tires through amazon. . Thanks Aced it. But i was paying so much attention to ordering the right tires that i forgot the tubes even though you mentioned it. How important is it to replace the tubes and the band? Do they really get worn out being that that they are inside the tires? Would a 15" tube be a 15 " tube or are there variables with the tubes like the tires? |
