#21 (permalink) | |
I myself would recommend replacement of the tube and the band at every tire change. Some will tell you upon inspection that there may not be a need. But, sometimes the tube can get pinched on removal or install, or the rubber can break down, etc ... I say do it (.) Yet another reason I went tubeless. Are you having a shop do the install?
![]() Keep the rubber side down ... unless of course you have a rubber head! My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf |
#23 (permalink) |
are these the right tubes for my bike?
front 120/90-17 back 160/80-15 1634159 - BikeBandit.com front 1634159 - BikeBandit.com back the guy at bike bandit says the 170/80-15 tube will work just fine with a 160/80-15 tire? any one ever done this? |
#24 (permalink) | |
#25 (permalink) | |
Rim flaps (Honda's term) should also be replaced. They are basically large rubber bands that keep the tubes from rubbing on the ends of the spokes. They are much less expensive than tubes -- maybe $3/each. Some shops won't change them unless you request it.
#26 (permalink) | |
So this is not the right sizes then? bike bandit told me their "Tube Size 4.00-17, 5.10-17, 130/90-17 " Will work for the 120/90/17 front tire and their "170/80-15 tube " will work for the back tire size 160/80-15 arn't the tube sizes they gave me bigger than my tire size? Last edited by bullheadpond; 12-13-2012 at 02:58 PM. |
