Noticeable noise when shifting from 1st to 2nd - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-09-2012, 12:55 PM   #11 (permalink)
Originally Posted by number13 View Post
My Shadow does that also, but I have been able to almost eliminate the noise and clash by placing a little upward pressure on the shift pedal just before clutching/shifting into 2nd. Try it!
I find CLUTCHLESS shifting is much quieter on mine. As far as upshifts go.... Most cruiser and tourer transmisions tend not to be suitable for clutchless down shifting though, wide ratios. Thats where shifter pedal pressure/support is helpfull.
Old 12-09-2012, 06:17 PM   #12 (permalink)
Thanks for the input, I think I just get a little worried when my shifter gets loose and it gets pretty darn loud
withoutatrout is offline   Reply With Quote
Old 12-23-2012, 01:44 AM   #13 (permalink)
utahmike's Avatar
Hey guys mine (97 shadow spirit 1100c) makes noise too but it isn't a clunk sound, more like a ratchet sound. Sometimes it is the mild clunk for a while, then goes to the ratching sound...is this normal too
utahmike is offline   Reply With Quote
Old 12-23-2012, 10:10 AM   #14 (permalink)
gat803's Avatar
A ratchet sound suggests grinding gears. Possible clutch adjustment needed or something else going on. Can you give a little more detail?? What oil is in the engine? Does it happen all the time? Cold or warm engine? Rider experience?
Hey look, a covered bridge...
gat803 is online now   Reply With Quote
Old 12-23-2012, 10:38 AM   #15 (permalink)
Scrapdog2grand's Avatar
I would second those statments,Cluch cable adjustment, Oil, or May need to be a little firmer and quicker on the shift.
1999 VLX
1998 SA750
2003 SA750
