My light in my speedo went out the other night in my 2002 750 ACE. I took the speedo housing off and looked underneath. Saw two screws in it so I took them off hoping to separate the speedo from the chrome housing. Looks like the lens needs to come off and the speedo needs to come out from the top. Does the lens unscrew or pop off? I didn't want to break it. And another thing, I didn't see a place for a bulb to go. Are they replaceable? Not that I look at my speedo anyway but it bugs me that something is not working on it.
#5 (permalink) | |
http://www.superbrightleds.com/cat/m...re-wedge-base/ |
#7 (permalink) |
Since we're talking speedo bulbs - I can see my speedo just fine, but the odometer is pretty dark. I haven't even looked at this myself, so apologies for that; but is there a separate bulb for the odometer?
'99 Shadow VT1100C Spirit - daily driver '99 Rebel CMX250C2 - Sold! '83 Shadow 750 - goodbye and good luck '72 CL350 - You never forget your first |
#8 (permalink) |
Regarding the bulb, read through this thread, 1157 LED Tail Lamp Bulb Thoughts. In this thread I also did a comparison and took a few pics for the speedo light, starting on page two. LED is the way to go!
![]() Keep the rubber side down ... unless of course you have a rubber head! My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf |
#9 (permalink) | |
Speedo x3, Odo, Neutral, water, oil, IIRC. |
#10 (permalink) |
Only one for the ACE. The plastic housing has a deflector in the design to help evenly disperse the light, thus reducing hot spots. A brighter bulb will do ya, however you'll need to go with an LED because it draws less energy and won't overheat your wires.
