1985 shadow vt500 nothing turns on Help!!! - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-18-2012, 07:19 PM   #11 (permalink)
Thank You
movinon is offline   Reply With Quote
Old 12-19-2012, 01:24 PM   #12 (permalink)
I have gone over every wire on the bike grounds and all removed headlight there are no brakes in the wires, all the fuses are good. I was wondering Im trying to give it a boost but the battery in the bike is shot could that maybe not give it any power?
Old 12-19-2012, 03:32 PM   #13 (permalink)
Did you check to see if there is voltage past the master link yet?
How did you determine that the fuses are all good?
Long version: You put a car battery on the bike battery connectors and had zero result. That means you have a problem with power movement which points to fuses and master link problems.
Short version: Don't ask for help if you are not going to let us help you.
Rock is offline   Reply With Quote
Old 12-19-2012, 03:33 PM   #14 (permalink)
I think we may have found your problem.
number13 is offline   Reply With Quote
Old 12-19-2012, 04:23 PM   #15 (permalink)
John Hopkins's Avatar
It seems that you haven't bought a multimeter yet but you are already stripping things off the bike..is this because you think the fault will suddenly get better if you do that..if you ask what the fault is and somebody on here makes a suggestion, it is just that, a suggestion..the only way to cure an electrical fault is by using logical fault finding because most electricity is invisible unless it is broken..
If a light is not working in your house would you stick a finger in the socket to feel if it has electricity.
John.
John Hopkins is online now   Reply With Quote
Old 12-19-2012, 05:15 PM   #16 (permalink)
I did try and use a multimeter it didnt seem to work at all when applyed to the positive and negative terimanals on the battery I had nothing.
Old 12-19-2012, 07:29 PM   #17 (permalink)
Do you still have the multimeter..was it a new one.. If you don't know how to use it you can blow it up in 7 nanoseconds..
As already said several times they cost under $10 for a new digital multimeter..get the meter and I will talk you through it..
Do not try using it without instructions..
John.
Old 12-19-2012, 08:02 PM   #18 (permalink)
Your Sunday paper probably had an advertisement for a free multimeter from Harbor Freight...
Old 12-20-2012, 07:07 PM   #19 (permalink)
It was an old one it was not digital, I will go by the digital one.
Old 12-23-2012, 12:04 PM   #20 (permalink)
okay I just bought a digital multimeter where do I go from here ?
