2000 ACE 750 electric problems? HELP!!! - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 01-06-2013, 06:34 PM   #11 (permalink)
Also, where is the kill switch on a Shadow ACE? I keep thinking fuel switch but I'm thining that's not it.
JRega is offline   Reply With Quote
Old 01-06-2013, 07:01 PM   #12 (permalink)
Scrapdog2grand's Avatar
The kill switch? on the right side controls run/off.
1999 VLX
1998 SA750
2003 SA750
Old 01-06-2013, 07:03 PM   #13 (permalink)
Dropkick_pride's Avatar
Big red button assuming its the same as my ace...
2003 Honda 750 ACE
Dropkick_pride is offline   Reply With Quote
Old 01-07-2013, 12:24 AM   #14 (permalink)
JP.
JP.'s Avatar
If its the kill switch, just hot wire the starter solenoid. Bridge the two big red terminals and your startermotor should run.
If it runs, soak your killswitch in WD40. Keep flipping it while you'r drowning it in WD40.
If it still won't run it could be your startermotor.
Its very common overhere in Holland that startermotors on the Shadows will heavely corrode on the inside and finaly they get stuck and quit turning.
Wooden shoes, Wooden head, Wouldn’t listen
JP. is offline   Reply With Quote
Old 01-14-2013, 03:35 PM   #15 (permalink)
PROBLEM SOLVED!!!
First I'm just going to thank everyone for their input and efforts toward getting the Green Beast back on the road (well kinda, still kinda shotty out for riding).
Secondly, Everyone prepare yourself with a good joke to throw at a young rider without a whole lot of experience maintaining his bike.
Plain and simple... The battery terminals were dirty and corroded. I didn't think they were, but when I took the seat off and tried to give it a start just for the hell of it I heard a pop again and just happened to catch a spark arcing between the battery's terminal and the battery cable.
I pulled the battery out and noticed there was some black coating on the terminals. Grabbed a brillo pad and some baking soda, and a little scrubbing later she's yelling at me without baffles
You never knew how much you missed riding your bike until it's been sitting for a month and then some.
Old 01-14-2013, 03:37 PM   #16 (permalink)
I think next I'll be taking apart the starter switch and cleaning the contact points as preventative maintenance.
P.s. She still doesn't have a name. Suggestions are welcome.
