Coolant leak, kill me now - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 4 (permalink) Old 12-19-2012, 05:49 PM Thread Starter
2002 Honda Shadow Spirit 750
Just did my valve clearance check and when I put everything back together coolant started leaking.
Words can not express my disappointment.
It's coming from the base of the metal pipe that comes out of the front cylinder up to the radiator inlet.
Couldn't find anything in the manual regarding this.
Anyone have a clue where to start?
CheddyRide is offline
post #2 of 4 (permalink) Old 12-19-2012, 05:57 PM Thread Starter
post #3 of 4 (permalink) Old 12-20-2012, 03:55 AM
corvin's Avatar
Send a message via MSN to corvin
Just replace the o ring rubber sealant.
That happened when the valvecover was removed.During removal the steel pipe was pried or pushed. The old ring cracked,now its leaking.
Honda VT 500 C 1983
corvin is offline
post #4 of 4 (permalink) Old 12-20-2012, 09:52 AM
Aced It's Avatar
Is the coolant actively dripping while the engine is running? Are you certain it's not dripping down from the hose connection above? Did you drain some of the coolant before removing the valve cover? If not, it may just be some coolant that spilled over down from the top of the tube when the cover was off. Otherwise, it could be the o-ring like stated above.
82 CB900C - CB Lingo for My Road
82 Magna - My Road is Magna-ficent!
91 VLX - My Road to Bob
03 ACE - My Road to Rod
From me to you: "Keep the rubber side down, unless of course you have a rubber head!"
Aced It is offline
